Question about Mackie 1202vlz3 12 Channel Mixer
Can i get a decent sound running an rca to usb cord from my mackie 402-VLZ3 to my macbook?
  • Mackie Master
  • 5,603 Answers
RCA jacks do NOT connect to the USB. One is aanalog audio, the other digital.
Posted on Sep 05, 2010
Hi, I have a Mackie vlz3 mixer. Last night I turned everything on and it was all distorted. I did some trouble shooting. It is definitely the board. Can you help. Ted
sounds like it could be dust or moisture ...Try cleaning the board and knobs and faders. this may help it may make it worse. Also while at it...check all connections...especially from board to amps. or to outboard gear. Could be a bad chord
Feb 22, 2015 | Mackie 1604 Vlz3 16 Channel Mixer
I have 1604-Vlz3 mixer recorded on cubase5 best matchable sound card is? I have M-audio delta 1010LT.This not so good sound.after recording. For like "Bollowood Hindi VocaSetting" EQSettings...
The problem is that card has only UNBALANCED inputs. You really need balanced or first run the mixer outputs through a DI backwards. Frankly, I would recommend NOT using a card within the PC as there is so much digital noise. Use either a USB or Firewire external convertor and for goodness sakes use balanced lines from teh Mackie... ALL interconnected equipment needs to be powered from the same receptacle or source. M Audio, Roland/Cakewalk and Presonus all make cards as do others.
Mar 16, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
What exactly do I need to connect a Mackie 402-VLZ3 to a Macbook Pro ? Where can I buy the cables? Thanks!
The internal audio systems in the PC's are inadequate for high quality work. You should get an external audio system that attaches via firewire or USB to your MAC. Then use balanced cables from the mixer to this audio interface. There are MANY different audio interfaces... Search the music equipment suppliers in the "recording" section of their catalog...
Feb 10, 2011 | Mackie 1202vlz3 12 Channel Mixer
Getting a high pitched hum that is coming from the usb connection on the back of the mixer running into my imac. i disconnect the cable and the hum goes away. ideas?
This sounds like a ground loop. Make sure ALL (including the computer) interconnected devices are powered from the same receptacle. Make sure there are no lamp dimmers around as these can cause hum...
Dec 19, 2010 | Mackie Vlz3 802 8 Channel Analog Micline...
Computer->M-Audio-FastTrackPro USB->trs outputs 1/2->linein 11-12 of mackie 1202-vlz3. How can i get stereo sound out of the mackie?
Use TRS to TRS balanced cables from the M Audio to the line in 11 and 12.
Set the pan controls for the 11 and 12 to opposite directions to split the stereo to left and right main outputs. (otherwise both main outs mix the left and right and you get mono result.
Feb 05, 2010 | Mackie 1202vlz3 12 Channel Mixer
Mackie 1604 VLZ3 Issue.
Hi kielhunt
It sounds like power supply issues.
You may have bad capacitors and/or bad regulators.
If you have a multimeter you can get in there and check the dc voltages for ripple(ac voltage mixed with dc) or over/under voltages along the +/- 15volts lines.
Good luck
Jan 20, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Hooking up powerd monitors to a Mackie 1604 VLZ3
Are you sending the main mix to the monitors or are you giving them their own mix? What about using the sub groups, use 1 for your monitor send.
Apr 04, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1202vlz3 12 Channel Mixer Logo
Top Mackie Music Experts
Michial Gueffroy
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Are you a Mackie Music Expert? Answer questions, earn points and help others
