No backlight on the screen - Computers & Internet
  • 221 Answers
This is always a hardware problem - you'll need to contact the manufacturer or a repair shop to have it replaced. Backlights are a common problem, and the only short-term solution is to smack it, and try to get the loose connection to work again... but it usually doesn't work. The backlight is an integrated part of the LCD screen, and gets replaced as a single unit. Good luck.
Posted on Sep 03, 2010
Testimonial: "Did not expected for an answer. Unbelievable. Any way my problem is from the motherboard and I'm looking to see if a can find a fix cheaper than 200£."
JVC LT-42E910 LED flat screen TV, backlight comes on, menu box is displayed but after about 5 seconds backlight goes out. Picture and sound still working but no backlight. How can I troubleshoot?
jvc tv backlight Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on jvc tv backlight related issues. ...JVC LT-40SX6AT flat screen. Was watching TV ... ...jvc logo, has sound but nopicture Backlight is defective. I suggest ... Question about LT-42E910 42" LCD TV.
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD ... LNT KDL Sanyo ln FLATSCREEN TV REPAIR FLAT SCREEN FIX - Hear Clicking .... i have a JVC LT42E910 WITH a cracked screen. there are all these color .... Vizio LCD Powers on with backlight, Wont power off, No video ...
Jan 11, 2016 | JVC Televison & Video
Why is my replaced lcd screen not lighting up?
1) Wrong LCD screen
2) Video Cable (LCD Cable) is not connected tightly.
Motherboard side, or LCD screen side; or both.
3) IF, a screen Inverter is used, the small cable from the Video Cable, that connects to the screen Inverter; is not connected, or has a loose connection to it. (screen Inverter)
4) An LCD screen, and a screen Inverter are a Matched unit.
If it's the wrong LCD screen......................?
5) IF, a screen Inverter is used; the diagnosis was wrong, and the LCD screen was replaced.
90 PERCENT of the time, the fault is a bad screen Inverter.
A) Laptop's LCD screen uses a CCFL, (Or more than one), for a Backlight; the laptop uses a screen Inverter.
Diagnostic flowchart leads from Graphics Chipset, to Video Cable, to screen Inverter, THEN, LCD screen.
Expensive LCD screen was replaced, instead of the actual part that needed replacing;
Video Cable: $9 to $22
Screen Inverter: $9 to $22
LCD screen: $60 to $245
B) Laptop's LCD screen uses LED backlighting, and does NOT use a screen Inverter:
Diagnostic flowchart is;
A) Video Cable;
A Video Cable should have it's connections PHYSICALLY checked.
You have to try to push the connectors in tighter.
Visual inspection alone will NOT do.
Making sure the Video Cable connections are tight, and this does not fix the problem, then the Video Cable needs to be removed; and every wire in the Video Cable checked for Continuity with a multimeter set to OHM's. (1K)
Not feasible, then take the Video Cable down to the nearest small computer shop; and have the resident tech check it for Continuity.
Should only be a few bucks.
Or just replace the Video Cable.
(Parts changing I know, but...........?)
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or more than one), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little large than 1/16th of an Inch.
Average thickness is almost as long, as the LCD screen is in height.
View the last 8 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A screen Inverter is used to convert the power, (Electricity), from the laptop; for the LCD screen, and Backlight.
As previously stated, Backlighting that uses CCFL, uses a screen Inverter.
LED backlighting MAY, or MAY NOT use a screen Inverter.
When the LED backlight technology first came out, it seems some did use a screen Inverter.
It also seems as the technology advanced, LED backlighting does Not use a screen Inverter.
Regards,
joecoolvette
May 14, 2013 | Sony Computers & Internet
Brightness buttons (f2 and f3 are not working
Not a lot to go on here, Prabhdeep
Need the full model information
Example,
Acer Aspire 5535-5050
Post back in a Comment, or Reply; at end of this solution
Primer:
An LCD screen does not produce light,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor icon
Because of this the LCD screen needs an additional light source.
CCFL = Cold Cathode Fluorescent Lamp (Bulb)
Average thickness is 2mm, or a little more than 1/16th of an Inch.
Or about the width of this capital letter -> O <-
Average length is almost as long, as the LCD screen is in height.
(Do they break easily when trying to remove, and replace?
OH, YES!)
A screen Inverter is used to convert the power from the laptop, for the LCD screen, and Backlight.
If the laptop uses LED backlighting, it MAY or MAY NOT use a screen Inverter.
Generalized thinking (Can also be stated as 'Rule of Thumb'), is that if the laptop uses LED backlighting, it does NOT use a screen Inverter.
I also feel into this line of thinking, since none of the LED back-lit laptops seemed to use a screen Inverter; that came to the shop.
I have found this to be a fallacy from on here,......FixYa.....
I have looked up two laptops using LED backlighting, and discovered they also used a screen Inverter.
Now I post LED backlighting may, or may not use a screen Inverter.
Seems when LED backlighting first came out, a screen Inverter was used on some models.
Also seems as the LED backlighting technology progressed, no screen Inverter is used.
90 PERCENT of the time, the fault for bad Backlighting can be attributed to a bad screen Inverter.
Of course, this IS IF the laptop uses a screen Inverter.
For a laptop with LED backlighting that does not use a screen Inverter, and backlighting is bad (Dim, or non-existant), the next hardware part in the diagnoses to replace, is the LCD screen.
I now await the information I asked for above.
Then we can diagnose together.
Regards,
joecoolvette
May 09, 2013 | Computers & Internet
I need a replacement screen and i'm not sure which cffl/backlight to order
Here are the eBay search results for your exact system model -
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+L355D-S7809+screen&_sacat=0
Sep 20, 2012 | Toshiba Satellite L355D-S7809 NoteBook AMD...
When buying a new LED laptop screen, do I have to buy a backlight as well or does a new screen include the backlight. Both the current laptop screen and backlight are damaged on my notebook.
Hi.
No, the backlight comes already installed with the screen. The only other thing that that you may have to replace (and i doubt it) could be the LCD inverter, but that is not part of the screen but rather the part which provides power to the screen so it will light up.
you should be fine with just purchasing a new screen.
Regards.
Jun 02, 2011 | HEWLETT-PACKARD HP Pavilion dm4-1162us...
The backlight won't turn on but occasionally will flicker.
Suggest you replace the Inverter. A Backlight goes out all at once.
90% of the time the Inverter is the hardware part at fault.
[ An LCD screen cannot produce enough light by itself.
A Backlight is used to supply the needed extra lighting.
A Backlight is a CCFL.
Similar to Fluorescent lighting used in homes, and businesses, but on a much smaller scale
An Inverter is used to required power for the LCD screen, and the Backlight.
Boosts power up for the LCD screen, brings it down for the Backlight.
Dell Support > Latitude D600 Notebook PC > Service Manual
http://support.dell.com/support/edocs/systems/latd600/en/sm/index.htm
Replacing an Inverter is a simple job. Replacing a Backlight is not.
The Backlight is located within the LCD screen assembly.
The metal frame of the LCD screen assembly is removed along the edge where the Backlight is located, to access replacing the Backlight.
In the above list for Service Manual, click on > Display Assembly and Display Latch.
This information shows you where the Inverter is located on a Dell Latitude D620 Notebook PC.
The Latitude D620 is part of the Latitude D600 series of Notebook PC's.
http://www.insidemylaptop.com/remove-replace-lcd-screen-dell-latitude-d620-laptop/
Just one place from a quick search, that sells Inverters for a Latitude D600 series Notebook PC,
http://www.parts-people.com/index.php?action=item&id=2895
MATCH the part number listed that they have, to the part number on your Inverter.
You have to have THE correct Inverter.
Regards,
joecoolvette
Nov 05, 2010 | Dell Latitude D600 Notebook
My laptop screen went black every thing is working but i cant see anything what might be the problem
hold the unit slihtly to a light if you can see the icons dimly on the screen then your screen has gone into freeze mode if you cant see the icons then your screen is probly blown to reset the screen from frozen it needs to be un plugged from the motherboard and plugged back in the plug is located under the panal above the keys
best luck
Oct 14, 2010 | Computers & Internet
Screen is to dark. cannot see letters very well.
Suggest you press the Fn key And the key to increase brightness, first. (Should be a key that has a sun icon on it)
Barring this does not increase the visibility of your LCD screen, the I suggest the Backlight is bad, or the Inverter.
The Backlight is a type of CCFL tube (Cold Cathode Fluorescent Lamp) mounted to the LCD screen. The LCD screen needs the light given off of the Backlight.
Replacing the Backlight is a daunting task, and if done wrong, will cause possible damage to the LCD screen.
The LCD screen itself has a thin metal frame holding the components of the LCD screen together. This frame must usually be opened on the side that has the backlight, to access the backlight. The components that make up an LCD screen are fragile, and can easily be damaged.
The Inverter supplies power to the LCD screen, as well as the Backlight.
Inverters do go bad, but commonly it's the Backlight to go first.
This shows a typical Backlight replacement. It IS not an advertisement to attempt this yourself, but a reference tool for information.
Nov 16, 2009 | Itronix GoBook III Notebook
Backlight is off
You either have a bad LCD or bad backlight board. The backlight on your screen is no different than a light bulb. If it burn out it stops working, if these is no power to the backlight your screen will have an image but no backlight to see the image.
Jul 03, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
