Question about Velodyne FSR-12 Speaker
I need a new amp for a Velodyne FSR-12 sub. Where can I get one?
3 Suggested Answers
  • 124 Answers
SOURCE: Velodyne ULD-12 driver voice coil sensor availability
Contact Velodyne. That is the only source for this part.
Posted on Jan 04, 2009
  • 124 Answers
SOURCE: Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Posted on Nov 21, 2009
I have 2 velodyne fsr 12 subs. both were taken out by PG&E power surges. One make a white noise that cuts in and out, but will still play bass when fed a signal, the other makes a loud static sound...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Velodyne-FSR-12-Subwoofers-manual/id/866ag600/t/2/
Not that it would help.
Is the white noise present in the absence of an input connection, free-floating?
The amps in both of them sound like they
Mar 24, 2011 | Velodyne FSR-12 Speaker
I need an amp for my sub 12
Search for "plate amp" on partsexpress.com. They have good selection of amps that will work.
Jan 21, 2011 | Velodyne CT-120 Speaker
Do you repair velodyne fsx 12 subwoofers
what is wrong with it ? is it the sub ? the sub surrounds ? the amp ?
more info please :)
Jan 27, 2010 | Velodyne SPL-1000 Subwoofer
I hear some noise coming out from the woofer of CHT-12R
It very well could be the spaker leads hitting the speaker cone.
You could check this by removing the amp section from the back.
Remove the screws at the very edge of the amp panel.
Jul 04, 2009 | Velodyne CHT-12 Subwoofer
When powered on speaker pushes all the way out
The problem is in the Amp. Velodyne is the only place you can get it repaired.
You will need to contact Velodyne for service
Mar 20, 2009 | Velodyne SPL-1500R Subwoofer
Hooking power amp to back of sub
Contact Velodyne.
Should have been a sheet in the box with amp for this
Feb 28, 2009 | Velodyne SPL800R Subwoofer Speaker
Velodyne subwoofer HGS12
Not able to help you in Brazil
Contact Velodyne via their web site
Jan 15, 2009 | Velodyne HGS-12 Subwoofer
Major buzz/Humming sound coming from my subwoofer
Well there are only a few reasons i can think of that just might be the reason behind said buzzing.
1. It may be connected to another power source ( amplified or powered supply ) or incorrectly connected. It may also be too close to said power supply.Try letting the dog (sub) out on his leash a little Drag out the manual that came with the sub, and check the correct procedure for your type of setup.
**People do read manuals still don't they ?**
2.The only other problem i have heard of is port noise in low registers. Keep the the port area clean, as it may suck up dirt, or even worse, small children!
3. However, if you're considering placing this subwoofer in a cabinet, I'd recommend allowing ample breathing room for the heat sink. This can also be done by drilling smaller holes in the cabinet ( 8-12 mm holes - with the owners permission of course) but please do remember to keep the port area clean.
4. The product ie: Velodyne DPS-12 Subwoofer, came with a bad power supply, presuming it is new, check your warranty.
(not very likely - see also scenarios 1, 2 or 3.)
Velodyne has been making subs forever and do it well.
Jan 17, 2008 | Velodyne DPS-12 Subwoofer
How to connect pioneer reviever to velodyne subwoofer
Look for the sub pre out on the back of your amp and connect a sub cable to this and next to the LFE or phono type input on the back of the sub ,if it has two inputs left and right pick the left side ,set the cross over to suit your system and speakers,if you are not sure set the cross over to 80 hertz,this is a thx standard.
hope this helps.
CABLE GUY.
Dec 27, 2007 | Velodyne DPS-12 Subwoofer
Top Velodyne Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Matthew Spark
Matthew Spark
Jerry Greenberg
Jerry Greenberg
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
