I am trying to hook up to the internet and tech support thru phone company says I have to reinstall network interface card? I'm clueless. Help!!
  • Charissa Natanauan
    Charissa Natanauan Sep 03, 2010
    what brand of computer are you using?
  • 37 Answers
You need to give your computer a static ip address as some times you pc wont pick up a ip address to do this go to networks device and properties and ip config and give it an addresss like 192.168.2.1.
In port your network card needs to be working check this by pinging it go to start > run type cmd the return it will bring a black box a command line, here you wont to type the following
ping 127.0.0.1
it should reply 4 time if it doesnt you network card needs to be reinstalled. if it does type the following
ping 192.168.2.1 if there is no reply try 192.168.1.1
these are the typical ip addresses for routers. you should get back 4 replys.
now if we are getting are reply from say 192.168.2.1 the you need to setup you pc with a static ip address like 192.168.2.3
usually close to the routers ip address. you do this in the network sectiob of you os.
hope this helps
Posted on Sep 03, 2010
    Sergeant:
  • 172 Answers
You have to download the drivers from the manufacturers website e.g. Dell, Lenovo, HP
once you go to the manufacturers website select support then download the correct drivers under network adapters or something about network.
I have a Netgear Wireless N150 router. It has been installed on our 2 computers. However, I had to reinstall Windows Vista on one and when I tried to reinstall the router, it tells me "No working...
Sounds like the driver for the network adapter has not be installed following the re-install of vista
to verify
go to start-->control panel-->System
Click on 'Device Manager'
Look for any devices that have a question mark or exclamation mark next to them
I suspect you will find something like 'Ethernet controller' which wont be configured correctly.
You will probably need to download the driver, using your other machine and then transfer to the problem machine and update the driver
If you need help identifying the driver then please provide details of the make/model of your PC.
If this doesn't solve the problem then let me know before rating this answer and I'll try to help you further
Good luck
Sep 06, 2011 | Computers & Internet
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
GET A MESSAGE: NO INTERNET CONNECTION DETECTED
Check the network interface card where the RG45 network cable plugs in, and verify that both the amber and green lights are on. One normally flashes the other stays lit. If not? Check the router/switch/modem for light activity where the same cable is plugged into. Also try uninstalling and reinstalling the network interface card device in Device manager. Reboot after doing so to see if that fixes your problem
Jul 26, 2009 | Computers & Internet
Network interface card
You need to go into device manager (control panel, system, hardware, device manager). Under Network, highlight your network interface card, right click and select uninstall. Once it's uninstalled, reboot your computer and it will automatically install it again.
Jun 14, 2009 | Panasonic Computers & Internet
I was told by my isp that I need to uninstall and then reinstall my network interface card. How do I do this?
Go into device manager (control panel, system, hardware, device manager). Under network connections, right click your network interface card and select uninstall. Reboot the computer and it will automatically reinstall.
Jun 14, 2009 | E-Machines eMachines Desktop PC
Wireless connection?
Basically you will have to connect the router between your PCs network adapter and what I assume you will have would be a broadband modem... You would connect them using ethernet cables, one from the modems ethernet port to the routers internet port (WAN port), the second ethernet cable would then be connected from one of the routers LAN ports (of which I imagine that there are 4 to chose from)... for the sake of arguement use port 1 and connect the other end to your PCs network adapter (aka NIC card, NIC, ethernet card, ethernet adapter) But wait, were not done yet!! lol You then must run the setup CD from your PC, follow the instructions from there... The CD will guide you thru the various settings for the routers global settings, wireless settings and firewall settings... If I remember correctly the website address for the routers web interface is 192.168.1.1, the username will be blank and the password is admin (factory default) til you change them if you decide to... Otherwise login to the router with your username and password (if you changed them)... There you will navigate to the wireless settings page so you can write them down for reference when setting up your Wii... That should be a good start... Any more questions I'll be happy to answer
--Joshua79
Apr 04, 2009 | Linksys Wireless-G Broadband Router
Can't send a fax.
You need to have a phone line not just internet connection to send a fax. Unless you have an account with a fax to email company. So you need to hook your fax machine up to your already exsisting phone line, get a seperate phone number for fax purposes or serch the internet for a fax via email company.
Jan 14, 2009 | Lexmark P4350 All-In-One InkJet Printer
E machine T6216 won't connect to Internet anymore
Go in device manager and find the network card drivers rolback the drivers then restart PC if that is not wor rinstal the drivers
May 26, 2008 | E-Machines eMachines Desktop PC
Dropped calls
Hi  Ahinee,
Most of the audio issues happening because of the internet issue. I understand your internet speed fluxuates. Can i know your Upload speed, Network setup, cable modem make and model?
Oct 12, 2007 | 8x8 Packet8 Broadband Phone Service...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
