Question about Goodman CKL36AR36 Air Conditioner
What size units do i have 1 is model #ck130-1b the other ck 7541b thanks
  • 24 Answers
Ckl36ar36 is a 3 ton. If both came as a set it should be a three ton system.
Posted on Sep 03, 2010
Humidifier is draining on floor while bucket is not yet full- why?
ck that float level in corner of bucket is free and moves well , also verify that unit is level as this affects the float and amount that bucket can hold , also a ck that drain hole that allows water to enter into bucket is not partways plugged with something , should be pencil size hole there
Oct 01, 2014 | Danby Dehumidifiers
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
What is the cu ft of this fridge
the tell the cu size ck the model # as its in the # like a amana model arb 23tbs / this would be a 23 cu ft unit hope this will help . mm
Jan 20, 2011 | Refrigerators
Model K 7622100 Ladies watch. Purchased in France less than 1 year ago. Face glass has become detatched and needs repairing. Please advise
Try the following links:
http://www.watchdoctors.co.uk/calvin-klein-watch-repair.htm
or call a CK customer service at 1-866-513-0513
Or try a local watchmaker and see if its possible to have them cut the right size for you.
Aug 11, 2010 | Calvin Klein Ck Flash K3424104 Watch
Outside unit not running, inside unit is running, but blowin heat. Goodman unit MODEL CK-J60-1
eletrick furnace? then it is a stuck heat sequencer(relay) the first stage heat sequencer also runs the fan in heating
Jun 26, 2010 | Goodman CKL60AR60 Air Conditioner
Goodman cpl-j42-1a a/c unit, fan on outside unit not working, inside there is cool (not cold) coming out of vent..
sounds like you have a bad fan motor in outdoor unit or a bad run capacitor ck cap first you can go 1 size larger than listed on motor data plate
Jun 10, 2010 | Goodman CKL42AR42 Air Conditioner
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
Heat works fine during the day at night it stops if you run hot water power vent turns on then boiler fires is it the presure swith in the power vent its model ck-92fal thanks ron
Turn on the boiler and jump out the pressure by putting a wire between the 2 electric connections only after the unit fires up than put the jumper on, if it runs ok it is the pressure switch.
Jan 08, 2010 | Calvin Klein The Field Controls Company...
Washer stops in middle of load and flashes F11.
this is not good . F/11 CODE serial communication error . the communication between the central control unit (ccu) and the motor control unit (mcu) cannot be sent correctly . now that sounds bad . don't panic!! ck the wir harness connectors to the mcu ( motor ) and ccu ( program panel . something is loose/ also ck the drive systen for any worn of failed components .belts/pulleys/ leakage.. ck mcu/ the ccu/ ck motor/ ck wire harness. -hope this will help . (look for loose connections this is most common.. mm
Dec 02, 2009 | Kenmore Elite HE4 Electric Dryer
Oil bolt has rounded of what size is the bolt??
fit in a helical, and keep in the same bolt, that should solve your problem
Feb 18, 2009 | 2005 Kymco Stryker 125
Goodman CKL36AR36 Air Conditioner Logo
124 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
