Question about Electrical Supplies
I need to know if an electric Kracher power washer model K3.99 will safely run from a Honda2000ia generator. The Kracher says 1800w on it.
  • 2 more comments
  • lrd5 Sep 03, 2010
    I am concerned about using a Kracher Power washer rated for 1800 w with a Honda Generator rated at 2000w because I know startup is usually higher....is that a concern in this situation?
  • lrd5 Sep 03, 2010
    I am not understanding where you got the 1300 w figure from?
  • lrd5 Sep 04, 2010
    Thank you so much, I feel satisfied with your answer because this is what I was concerned about....and you gave me a fact based answer...thank you!
  • lrd5 Sep 04, 2010
    Loved having the facts!!!!
    President:
  • 1,383 Answers
According to Honda data sheet the AC Output of your gen is 120V 2000W max. (16.7A) 1600W rated (13.3A). Your pressure washer uses 1800w which is equal to 15.6 amps. Most likely your washer will pull/spike much more power when starting and increase slightly as the unit motor heats. I worked at a tool rental company while attending college and utilized charts for recommending generators for projects. Minimum for 1800watts power requirements is 2250watt gen, however the smallest we rented was 2500watt. Your generator is perfect for camping due to small size and very quiet operation. Do not risk damage by using it for your pressure washer. Good Luck
Posted on Sep 03, 2010
  • 10,319 Answers
Look at the wattage output on the pressure washer
If under the rating of the generator you will be fine
  • frank thomas wilson
    frank thomas wilson Sep 03, 2010
    the start up consumes less power from a capacitor rated at 1300 watts on the starting unit of the power washer
Why does my husky 6250 generator run but not produce power?
Anon, If it has sat for quite a while, you may have to field flash/re exite the generator. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to re energize Dead Generator
Flash Your Generac Portable Generator with Corded Drill
How to test your Electricity Generator AVR Brushes and Alternator on...
Diagnosing Generator That Has No Power Output
Jun 08, 2016 | Husky Electrical Supplies
I need a owners manual
Owner's Manual - Northern Tool + Equipment
www.northerntool.com/.../manuals/166114.p...
Northern Tool + EquipmentOtherwise, back feed from the generator into the power grid could kill utility workers...... information, always refer to the engine Owner's Manual furnished with thegenerator. .... (a) Hard-starting motors require 3-5 times the rated running watts.
Online Product Support - Generac Power Systems, Inc.
www.generac.com/.../product-support-lookup
Generac Power SystemsOr how about a new hose for your pressure washer? Shop and buy genuine Generacparts and accessories for your home backup generator, portable generator ...
[PDF]Owner's Manual - Home Depot
www.homedepot.com/.../66508163-2ff4-4048-9162-0...
The Home DepotThis manual contains important information that you need to know and understand in ...Power Output. This generator is not designed to power sensitive electronic equipment... Do not touch electrically energized parts of the generator and.
[PDF]Owner's Manual - Smarter Tools
Jan 21, 2016 | Electrical Supplies
I HAVE A GENERATOR HONDA E2500.
the generator is not big enough to run what you want
it needs to be 3500w minimum or 4.5w to be safe
although it is stated at 2500 watts , in fact that is the peak load on electric motor start up and its continuous rating will be around 1.8 watts
all of this is clearly stated on the specs plate on the generator
Dec 06, 2015 | Honda Generator E2500 Vintage Great...
Need Owners Manual for an ETQ 1800 w inverter/Generator
Northern tools has it here, even though it's a discontinued product:
http://www.northerntool.com/images/downloads/manuals/166520.pdf
Apr 11, 2013 | ETQ IN1800i Generator Digital Inverter...
Where can I find a owners manual for superworks 1800w portable generator
Have a super works 4 stroke 1800. Have lost manuel and need valve clearance
Apr 13, 2012 | Electrical Supplies
Need to know what oil to use for oil change in the kracher by honda
engine oil....10-30...sh/sj.......19.52 oz do not over fill
oil in pump is a special oil through karcher....3.52 oz of pump oil
Jul 15, 2010 | Karcher 2500 PSI Pressure Washer
Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Mar 07, 2010 | Electrical Supplies
No output
you need to replace your breaker frist. than check your rotor ohm and than your stator for shorts. you may want to check the cover were the bearing is there is a metal ring that may have came out and hits your brush cover. look for black burnt marks
Oct 13, 2009 | Coleman Powermate Premium Plus 6250W...
Will not run
buy a gas powered they last 10 times longer.
Jun 13, 2009 | Garden
Pressure Washer Engine will not stay running
My Kracher 2500 pressure washer has no pressure unless I remove the nozzle. If, I remove the nozzle and pump the trigger several times and quickly replace the nozzle it works fine until I release the trigger. Karcher (online) suggested I remove and clean the unloader which I did. It still doesn't work correctly. What another solution?
May 29, 2009 | Garden
Electrical Supplies Logo
96 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
