Question about Whirlpool GR465LXLS Electric Kitchen Range
Stove MY stove will not turn off. I had to unplug it. The comlete stove was hot.What could the problem be?
  • zumo May 11, 2008
    my oven would not preheag and then the oven would not turn off and the whole range got hot and I had to unplug it. What part do I need to buy to fix it?
  • 3,037 Answers
It is probably a relay that has gone bad or a broken connection. You will have to open your oven and check the connections and relays and see if any are fried or broken.
You can also test them with an ohm meter to see if they have continuity
Let me know if you need any further help figuring this out and I would be happy to help
Posted on May 11, 2008
    Genius:
  • 3,587 Answers
Hmm...sounds a bit like the heating from when it's on self cleaning mode...the unit will seem to overheat and then it's really tough to work with. Sounds like the control board is unhappy. Do you like to get into these sort of repairs?
    President:
  • 2,712 Answers
It could be that one of the infinite switches has shorted out. The infinite switches are the ones you’re turning when you turn on the surface elements. You’ll need to open the control panel to access the switch wiring. It could also be a problem with bad wiring.
In any case, I recommend that you consult a professional to get this fixed.
you can find a local service center here:
http://shared.whirlpoolcorp.com/sharedservices/dealerlocator/dealer_search.jsp?siteCd=WHRCOM&dcsref=http://www.whirlpool.com/custserv/index.jsp
or Call 1-800-253-1301.
Hope that helps!
  • Swilin Sampson
    Swilin Sampson May 11, 2008
    Please NEVER rate a solution without giving all background information first. Once a solution has been rated, and you come up with more info, the expert may not be willing to post a reply even if he has the solution.
    You cannot always expect an immediate answer. Sometimes to and fro dialogue may be necessary before we can get to the root of the problem..
    Sergeant:
  • 264 Answers
You should call the whirlpool engineer.
I have a kenmore range # 79094152310. And when I turn on the right front burner, the top of the oven gets so hot you would get burnt if you touched it, is this normal for this stove?
no --not normal
stoves even glass top stoves are only hot in vicinity of the hot plates
if the whole top is hot , call an electrician in to check the systems
Oct 02, 2016 | Kenmore Kitchen Ranges
Electric stove
Check the thermal coupler a copper thermometer for your stove after checking all the fuses in stove and circuit breaker box of house to see if any have tripped. Circuit Breakers should have the switches all in a line. Any not in the lie will be tripped. Fuses in your stove are usually in the top part of the stove where the instruments are and fuses screw out and visually are easy to detect if they are blown or not. Remember all ways Unplug what you are working on to prevent shock
Jul 03, 2013 | Ovens
I have a Whirlpool electric range RF263LXTQ2- 2 yrs old-it gets so hot that the large burner pans are both charred black. Had it looked at about a year ago and couldn't find any problem-top and front of...
Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
Mar 13, 2017 | Whirlpool RF263LXTQ Range
Lazer 30 error 22 on panel
The stove quit three times with an ee2 message. The stove is trying to save you from flooding. You may have a fuel problem that is causing the ee2 problem. After three time the stove locks out and won't let you try again. Find out whats up with the fuel. Unplug the heater for 20 minutes and you will be able to try again. Also make sure the igniter is getting hot. Two red wires going into the burner should get hot.
Tom
Sep 25, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Preheated stove put in cake a few minutes later smelled burning and cake was burnt on top.. Broiler was on and running hot as heck. tried turning off stove but would not shut off.. Unplugged. Let satand to...
Probably the control relay has shorted. But first check the voltages at your receptacle to insure that a neutral is not floating. You should fine 120 from each hot to the neutral.
Jan 09, 2010 | Kenmore Kitchen Ranges
Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
Oct 08, 2009 | GE Profile JKP18 Electric Single Oven
Hot surface light
across each plate there is a cutout - you can usually see it thro the ceramic and is a rod going across the plate. it also senses that the plate is hot and turns the hobhot light on. this is the part that is faulty. sometimes only available as a complete plate
Sep 02, 2008 | Frigidaire FEF366 Electric Kitchen Range
Burner will not turn off
I would first check the infinite control switch (#WB24T10029) the part the knob slips onto. The next thing I'd check is the erc (#WB27T10231) control board. Hope that is helpful!
Mar 05, 2008 | GE JBP64 CleanDesign Electric Kitchen...
Whirlpool GR465LXLS Electric Kitchen Range Logo
93 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
