Question about Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY
How to dismantle a jacuzzi magnum pool filter pump 1228
  • 990 Answers
When you go to loosten the lock ring you will need to find the lock tab that will keep it from comming off. This tab I think will pull out but it may push in and this will free the ring to turn. Once this is off if the motor runs turn it on for a second and let it push the front and back half apart. If it won't run you can use a flush bag to pressure it off. In worst case you can pry the halvs apart with a big screwdriver. If you do this be careful not to hurt the case of the pump it is just plastic.
When the pump is opener you remove the difusser and look inside the impeller. If you have a screw in the center of the impeller it will be a left hand thread so to remove you will turn it clockwise. Now just unscrew the impeller turning it counter clockwise and take the rear plate off the motor by removing the four bolts on the back. Good luck.
Posted on Sep 04, 2010
My jacuzzi magnum force pump is hot is this normal?
the pump is pumping and circulating hot water into jacuzzi, it will get hot. I think it is ok
Jul 06, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
I need a motor end cover, where can I get one? Thank you!
Jacuzzi (Carvin) Magnum, Force & Plus pump parts are hard to find.
Here is a link to our site which has a parts explosion/diagram for those pumps.
Jacuzzi Magnum, Magnum Plus, and Magnum Force Pumps
Jun 08, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
I would like to know the noise level of a jacuzzi magnum pump 1.00 hp in decibels.
This is not possible as it completely depends on the amount of total dynamic head the pump is connected to as well as the voltage level that is being applied.
Mar 29, 2011 | JACUZZI MAGNUM FORCE POOL PUMP TWO SPEED...
Hi I have a magnum 1000 Jacuzzi pump for my
alot of companies use to have a damper ring on pump shaft which would knock down some of the noise a pump motor made pumps make noise and the bigger the pump the louder the noise if its not vibrating or clunking then its running as it should
Apr 21, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Which valve do I use on the Jacuzzi Magnum 1500 to drain lines
There two plugs on your pump, one one the side of the pot at the bottom and one dead center of the pump housing on the front. this will only drain your pump if you live in cold country and are winterizing you will need to drain all your equiptment filter, heater and any thing else. then you need to drain your pipes and seal them at poolside to keep the water out.
Sep 26, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
My jacuzzi pool pump cracked so I need to replace it. Jacuzzi is no longer making parts, so what would be a good brand where I could still use the same pipes, filter, etc.?
here's a site where I found tons of jacuzzi parts and accessories.
http://calwesthot1.reachlocal.net/AdvancedSearch.aspx
under select catagory scroll about half way down to jacuzzi pumps and hit search.
If you find what you need can I borrow the jacuzzi .. lol
Jul 31, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
My pump is running however it's pressure is less than 10 psi and the heater on the pool will not run.
With the Jacuzzi Magnum pool pumps, low pressure is going to likely be cause by one of the issues below. Try these troubleshooting tips.
1.Pump not primed
2.Leakage of air into suction system
3.Impeller clogged
4.Valve in suction or discharge line partly closed or suction or discharge line partly plugged or too small. 5.Plugged basket in skimmer or hair in lint strainer.
6.Dirty filter.
Jun 06, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Pump noise
sounds like it needs new bearings, take it to a pool professional.
Jun 04, 2009 | Jacuzzi MAGNUM 2 SPEED POOL PUMP 2.0 HP
Jacuzzi magnum pool pump impeller broke
The impeller on the Magnum pump unthreads counter clockwise as do other impellers. There is a shaft of the motor that runs the length of the motor, on the back of the motor when you take the bell housing off you will see a small silver spot with a **** in it for a standard screwdriver. Put the biggest one in there you can and then grab the impeller and turn it counter clock wise and it should unthread. Sometimes they won't if it has been on there a number of years. You will need to break it off if it doesn't unthread. Then just purchase a new Impeller for the Jacuzzi Magnum Pump.
Rod
US Parts Center
Feb 24, 2009 | Pool & Spa
Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY Logo
1,129 people viewed this question
Top Jacuzzi Garden Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
