Question about Kitchen Ranges
I HAVE A GE MICROHOOD MODEL GH7155XHS AND THE FAN WONT SHUT OFF. IT WILL CHANGE SPEED AND WHEN YOU PRESS THE BUTTON TO SHUT OFF THE DISPLAY READS OFF BUT FAN IS STILL RUNNING ON LOW. WHATS UP
  • jimmyzinstal Sep 03, 2010
    this is not the internal blower its the exhaust fan motor that only operates when you manually turn it on! there is no sensor for this fan assy. i know which fan your refering to this is not that fan
  • jimmyzinstal Sep 07, 2010
    thx for your time
  • Kitchen Ranges Master
  • 12,061 Answers
Hi, well it would appear that the speed controller has failed, Iimagine one or more of the output semiconductors has gone to a short, or partial short circuit internally, thus allowing some current to leak through them and flow through the windings, even though the unit has been tuned OFF. I have seen similar things before.
In this instance, you would be best advised to replace said speed controller board, or if integrated, most likely, then you may have to obtain a whole new main board? You will have to check with GE.
I suggest you contact GE, and ask if you can obtain replacement parts, and try to obtain a service manual, from then too, this makes any repair possible.
If you do not wish to DIY, them please call an authorised service center and request a service call, remember to always ask for a "Quote" before allowing any work to commence.
Posted on Sep 04, 2010
    Genius:
  • 1,478 Answers
This could be as a result of either a defective sensor or normal operation to maintain air flow until all parts have cooled off. this are the two possible reason, so, you will need to observe to determine if it is to maintain air flow until all parts have cooled off/otherwise.
Take care.
Posted on Sep 03, 2010
My change oil display on my 2005 ford explorer i changed the oil and it wont go out
Press your reset button on the on board diagnostics which is located on the dash, keep pressing the rest button until you see "oil life" once you come to the oil life, hold the reset button until it reads "Oil Life 100 percent" release the reset button, shut the vehicle off then re start it, that will turn off the message in the message center telling you to change your oil.
Oct 18, 2011 | 2005 Ford Explorer
I have a 2003 kia sorento and my a/c and heater display reads celcius how do i change it to ferenhiet
Push the ambient button and the up/down temp button for 3 seconds. up for celcius down for ferenhiet if I remember correctly
Dec 26, 2009 | 2003 Kia Sorento
Cant send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 27, 2009 | Lexmark X6170 All-In-One InkJet Printer
Can't send faxes. Dials Ok but no connection to send fax
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Cannot send a fax
Apr 29, 2009 | Lexmark X4270 All-In-One InkJet Printer
Can send faxes but cannot receive - shuts off after 2 rings
Apr 19, 2009 | Lexmark X4270 All-In-One InkJet Printer
Change name on a Nortel M7324
1. Press the Rls button then ** FEATURE 266344 (CONFIG)
2. Password is 23646 (ADMIN) The display reads Terminals & Sets
3. Press SHOW ans enter the Extension for which you want to enter a name.
4. Press SHOW, again
5. Press the NEXT key until the display reads NAMES at the top left corner.
6. The bottom right corner reads CHANGE, press the far right soft key.
7. To move from one letter to the next use the far right and far left soft keys or the # key.
8. When you are finished Press next.
9. Press the HEADING key to get back to TERMINALS & SETS and start again!
Navigation Keys: Line 1 = HEADING Speed Dial = SHOW
Line 2 = BACK Last No. = NEXT
This can only be done from the main handset and only one at a time. The Soft Keys are the three small buttons right bellow the screen.
Jan 28, 2009 | NorStar M7324 Telephone
Speed dials
I'm not sure if this will help because I haven't seen a 2060 control panel but most Canon fax machines use the same process. Press either "menu" or "data registration" button. (Again -I'm not sure of 2060 control panel.) Display should read "user settings" Press the "down arrow" (looks like an upside down triangle) until the display reads "tel settings" Press "set" Display reads Speed Dials Press "set" Display should give the # of the speed dial (ie. Speed Dial 01) Press "set" Display reads "tel number" Press "set" input # you want to send faxes to Press "set" Display reads "Name" Press "set" use letters on keypad to input receivers name (ie. For letter "C" press #2 three times, you may have to use the arrow keys to move the cursor for names such as BC Corp) Once name is input - you guessed it- Press "set" you will now be presented with various other send options which most people/businesses never use. You can hit stop to return to normal mode. After inputting speed dial #'s & names,you can print a list of what you have input by getting back to the "Tel registration" screen & pressing the report button. I can be reached @ bspier@carlsonsupplies.com if you need more assistance. Good Luck!!
Jun 09, 2007 | Canon LaserClass 2060 Fax
FAN ON MICROHOOD CONTINUES TO RUN WHEN PLUGGED IN. HI IS LOW & LOW IS HI.
If you have Acrobat Reader you can see an exploded diagram of this model here: http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00018000/00018081.p01.pdf Ref # 110 and 115 are thermostats and ref # 27 is the hood thermal cutout. One of these devices is likely bad. You can order them via GE online at http://www.geappliances.com/shop/prts/ or via Sears online at http://www3.sears.com You should also be able to find them at local appliance parts stores. Here are the GE part numbers and prices: TCO HOOD REF# 27 WB27X10789 $11.50 THERMOSTAT,BIMETAL REF# 115 WB27X10506 $21.75 THERMOSTAT- BIMETAL REF# 110 WB27X10788 $12.75 Good luck.
Oct 29, 2006 | GE JVM1542 Microwave Oven
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
