Sp2004c sata hard drive is not recognised on system by bios or samsung hard disk manager all pluged in corectly to a new m/b, please help built a few pc`s now and not had this prob b4
  • willys1 May 11, 2008
    thanks 4 this, i did try that even tho the M/B supports 3.Gb/s but no joy, the only thing i can think of is the Hd is naff, looked all thro the bios and sata controller is enabled is there anything else i coild l@@k @
    many thanx 4 your imput, much appreciated
    Willy
  • 655 Answers
  • Some SATA HDs have jumper for 1.5 G (SATA I) and 3 G (SATA II)mode. Try switching the jumper to 1.5 G or SATA mode (see motherboard manual).
  • Or you might need to upadte BIOS to support SATA drives.
Good Luck
Iqbal
Posted on May 11, 2008
Half capacity
Please check it in here (probably there is an unallocated space):
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management.
Feb 27, 2014 | Samsung SpinPoint P120S (SP2004C) 200 GB...
Hard disk not recognized by computer hd400ld
Check connectors. Check if you installed hard disk correctly (master / slave option on the disk itself). Check BIOS if the drive is recognized. Start computer up with a valid system on a disk. Start up a disk Partition Manager. Assign a drive letter to your new drive. If necessary create partitions and format as NTFS or FAT32.
Sep 14, 2012 | Samsung SpinPoint T133 HD400LJ 400 GB SATA...
My bio-star p4m800-m7 mother board won't detect my 1terabyte sata hard disk, currently i'm using 160gb ide hard disk....i need to have additional storage...but the system cant detect sata...need...
Hello,Please check the BIOS to see if the SATA ports are enabled. Older boards will disable the sata ports in the BIOS by default. To enter the BIOS, hit the DEl key as soon as you boot the PC.
If ports are enabled, then you probably have to format the drive.Heres how:1. Right-click My Computer and select Manage.
2. Under Storage, click Disk Management on the left pane.
STEP 3 - Format the device / drive / MP3 player
1. Right-click on the 1 TB drive you want to format then select Format.Windows will not recognize the drives file system and will mount it with a drive letter. ex; E:
Sep 09, 2011 | EliteGroup P4M800-M7 Motherboard
I have a compaq witha samsung hd M/NSP2504C, S/N S09QJ1ULB30333. What are the speed and buffer specifications and which hard drive would you recommend for a compatable replacement or slave.
Hello
Samsung SP2504C is a 250 GB hard disk drive using the new SATA-300 interface, which allows a maximum theoretical transfer rate of 300 MB/s. Its main specs also include an 8 MB buffer, 7,200 rpm rotation speed and support to NCQ (Native Command Queuing). In this review we checked the performance of Samsung SP2504C installed on a motherboard using a regular SATA-150 port and also on a motherboard using the new SATA-300 port.
This very same hard disk drive is also available with a 200 GB capacity, being called SP2004C. Both belong to SpinPoint P120 series from Samsung.
Good LUCK AND DO RATE THE SOLUTION IF HELPS
Dec 20, 2010 | Compaq Computers & Internet
Samsung HDD not seen by Vista I recently purchased a Samsung HD154UI Hard Drive for my Vista 64BIT System. I have enabled the hard drive in the Bios. I now have a 500GB drive on SATA 1 and the new...
This won't be the best solution for you perhaps because I'm not a windows guy, but download the gparted (just google for gparted) cd image, burn it to disk and boot it up. Use that to partition and format the drive.
Aug 05, 2010 | Microsoft Windows Vista Home Premium...
I've connected my Samsung 250GB HD250HJ SATA drive (from a Linkstation) to my PC with a sata-ide adapter. It's recognised at boot time but I get the message 'primary master hard disk fail'. It isn't...
You may need to address the way that the old HDD was used in the BIOS. Meaning that if you had regular IDE drive the setting that may be in the BIOS might need to bee disabled and that could be the cause to the new SATA IDE controller you have installed as a boot device. Also if you are trying to boot from you new SATA drive you will need to install some form of and operating system on it like windows or whatever you have been using.
Sometimes it’s easier to create a disk image of the old drive and transfer it to you new SATA, using a disk image utility like Norton Ghost.
Of course I am assuming that you are using a PC and not a MAC.
-Aaron
Dec 05, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Hard drive model: HD103UJ (1000gb/7200RPM/32M) I connected it to the pc..but cannot find it..Do I need drivers or something?
If tou can find it in booting time on bios screen, Just goto,,, start>control panel>Administrative Tools>Computer Management>storage>disk management. You should see the new drive. Click on it and try import foreign disk . it should bring the disk. try making new oartitions there.
Apr 20, 2009 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Unrecognized HDD-- need help!
You could also try setting the jumper on the hard drive to "limit to 1.5gb/s".
Oct 04, 2008 | ASUS K8V-MX Motherboard
Computers & Internet Logo
419 people viewed this question
David Payne
David Payne
