Question about Gigabyte GA-7N400 Pro 2 : ATX Socket A FSB400 DDR400 AGP8x SATA/IDE Raid w/audio Gb-LAN (NEWITEM121760113) Motherboard
Hi i have got a problem with the sata prots it will not say that there is a drive
    Sergeant:
  • 222 Answers
Try resetting the CMOS. 3 wire pin with a 2 pin connector. Just unplug computer and take the connector from pin 1 and 2 to 2 and 3. Wait a few seconds and then place back to pin 1 and 2. Then power up into BIOS and see what it says.
Posted on Sep 03, 2010
Hi i bought WD 320 gb sata /8mb hard drive - the cable ribbon on my dell 4600 does not plug into it! do i need a different cable yes
Generally speaking, we have two types of hard disk interface. IDE (the old one with ribbon cable) and SATA (with a 1cm strip like cable).
As your new hard disk is SATA, you need a SATA cable to connect it to you PC.
Below are a few images which would help you.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 23, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
Can i replace the hard drive parellel type of inspiron 2200 into SATA type hard drive?
Ofcourse you can replace the hard drive as Inspiron 2200 are usually supplied with SATA hard drives. But call Dell support team as they will only replace the hard drive if your computer has hardware warranty or else they will ask to purchase it.
Chio,
Anirban Mazumdar
Dec 04, 2010 | Computers & Internet
When I am running movie on my Samsung lcd on hdmi3 it is showing mode is not supported please help
first you have to confirm your tv other hdmi prot working?if yes then there is problem with hdmi prot 3 if you check in side tv there is one drive ic fautly. or your in put signal not same as in put tv.Please change the resulation it will work.
Oct 16, 2010 | Samsung Televison & Video
Swapping hard drives in laptops
if you want to use your old drive in your new laptop then your have go for new case 2.5" case which will fix your old HDD from USB prot u will able to use
frist chack your HDD it's ID or SATA according that u buy a case
Apr 21, 2010 | Gateway 4025GZ Notebook
Possible to install a SATA hard drive?
Yes it's possible you can Install thing is in your desktop mother board has a extra port or you can use Extranal HDD with USB Prot
Apr 09, 2010 | Acer Veriton 3600G PC Desktop
My computer will not recognized my external hard drive...
your usb prot is not working properly or pls check your hard disc
Apr 05, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Thank you for using fixya.
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
Sata & ide darddrives
Hi, All dual drive capable boards read the SATA first, just make sure both SATA & IDE are enabled in the BIOS, load your O/S as normal this will load on the 1st SATA and the others will be auto detected as drives D and E, the IDDE will be E by default. Regards mistyman
Sep 22, 2007 | Soltek SL-75FRN2-RL Motherboard
Gigabyte GA-7N400 Pro 2 : ATX Socket A FSB400 DDR400 AGP8x SATA/IDE Raid w/audio Gb-LAN (NEWITEM121760113) Motherboard Logo
147 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
