What happens if i touch the encoder film - Office Equipment & Supplies
  • 2 more comments
  • davro1966 May 12, 2008
    tried but did not work. the printer says it is unable to clean any suggestions i have tried averthing in the users guide.
  • eagle70 Aug 16, 2008
    I have a Brother MFC-3240C printer.Because I used generic ink brother says I can't fix it. The manual says DO NOT TOUCH THE ENCODER FILM AND DO NOT TOUCH THE PAPER FEED STAR WHEEL. I've bought ink and wasted half of it running it through the cleaning cycle. Is there anything I can do? I know this is for the Label Printer. Where can I find information on my printer? Thanks
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    i'd submit that your printer is compromised to the point of major service...wish it weren't so
  • Patrick Michaels
    as in that which is under the print heads?
  • 21 Answers
Nothing happens, it is simply a clear strip with black stripes on it. The printer counts the black strips tp position the heads.If the strip is dirty, you can clean it with water and MILD soap, never use force or abrasives or you'll remove the lines and the printing will be out of alignment.
Posted on May 11, 2008
  • Philip Carr May 12, 2008
    what model do you have. I doubt that the encoder has anything to do with head cleaning - it is used for lateral positioning of the cartridges. If the cartridges won't clean, you can usually use hot water on a non shredding cloth. Describe you exact problem
Mp 280 error p2?
This helped me last time i worked on this kind of problem....The Canon MP280 can display this error for a few reasons. It could be that one or both of the cartridges are not inserted into the printer correctly. One or both of the cartridges may have failed electrically, and need to be replaced.
There may be a paper jam, check the printer thoroughly for any small pieces still stuck inside.
The encoder film strip may have some dirty marks on it, and therefore needs cleaning. The encoder film strip in the clear strip of plastic that the printer carriage runs on. Be extremely careful when touching this, as it is very delicate.
Sep 02, 2015 | Office Equipment & Supplies
ISO DX ERR
What speed film? Does the roll have the DX markings (the black-and-silver rectangles)? If it doesn't, what happens if you set the film speed manually?
Mar 22, 2013 | Nikon N6006 35mm SLR Camera
Desk jet 2360 cradle thrown left and right repeatedly then cradle jams.repeated errror codes of catridge,paper jam etc
Unable to find the encoder by the carriage assm, clean encoder & encoder reader sensor. (encoder is just like a film printed with lines on it, located behind the cartridge carrier)
Sep 12, 2011 | HP Deskjet D2360 InkJet Printer
How can i change the ISO on my camera (minolta maxxum 3xi)? The film i put in is 400 but the assignment requires me to change it to 100
Okay. Just bear in mind that the exposure meter is going to be two stops off, unless you're getting the film pull-processed.
The Maxxum 3Xi unfortunately does not have a way of overriding the Camera Automatic Sensing portion of the DX encoding standard. That is, if the film cartridge has the DX encoding, the camera will set itself to the indicated speed.
However, if the film cartridge is NOT encoded, the camera will set itself to ISO 100. So, if you tape over the magnetic encoding on the cartridge...
The CAS is not the barcode on the film cartridge, but the rectangular patches of conductive and nonconductive material.
Take a look at http://en.wikipedia.org/wiki/DX_encoding for more information about the DX encoding.
Jan 13, 2011 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Error code 5100
Error code 5100 indicates that Carriage Return (CR) error occurs. This error rise when carriage unit (the part that function as cartridge housing) does not move properly. Here are some possibilities of the problem:
  1. Carriage unit is faulty so that it cannot 'read' film timing **** strip (film encoder) properly
  2. Film encoder is dirty. Film encoder functions as a guide for carriage unit to move to the correct position it should be. Carriage unit 'read' the encoder by flashing a light from a LED. Dirty encoder sometimes make the light direction is deviated.
  3. Foreign material blocking carriage unit path. Please check inside the printer and remove it if any.
If carriage unit is faulty, you need bring the printer to the service center to get part replacement. For dirty film encoder,sometimes you can still clean it by using moistened cloth. I hope this will HELP you. Thanks.
Get printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA MP160 All-In-One InkJet...
What is Error Code 5100 please
I asked around and this error ..its also instruct you to turn off and on the printer ..it is a warning for an obstruction in the printing process ...most of the times the obstruction having mechanical origins..So look around for sliding parts and in general parts that suppose to move in a certain pattern and now are blocked or not well lubricated or something is blocking them ..
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Canon i80 service error 5100
Hi guys,
Service error 5100 indicates that carriage return (CR) operation is not performed successfully. After the printer turned on, printer initialize some operation include CR operation. This error happens when carriage part (carriage unit) has problem when move right and left in initialization process.
This may be caused by:
  • Faulty carriage part so thatit cannot read film encoder properly. As a result, carriagepart move on uncontrolled.
  • Dirty film timing **** strip (Horizontal film encoder;available only ini series and above) so carriage part cannot read film encoder properly.
  • Another material (such as broken paper, etc) present in carriage path, blocking carriage part from moving.
To fix this problem you may try the following tips:
  • Check if any material present in carriage path; remove (clear) it
  • Check if film encoder is dirty; wipe slightly with moistened clothe.
  • At last, if carriage part is faulty you need to replace it.
Hope this will be helpful for you. Please don't forget to rate me.
Regards,
Source:
Inkjet Printer Forum
Dec 24, 2008 | Canon i80 InkJet Printer
Canon i80 error 5100
Hi antoinette,
Someone has ever asked this problem and I have post a solution for this. Here is my answer:
* Faulty carriage part so thatit cannot read film encoder properly. As a result, carriagepart move on uncontrolled.
* Dirty film timing **** strip (Horizontal film encoder;available only ini series and above) so carriage part cannot read film encoder properly.
* Another material (such as broken paper, etc) present in carriage path, blocking carriage part from moving.
* Check if any material present in carriage path; remove (clear) it
* Check if film encoder is dirty; wipe slightly with moistened clothe.
* At last, if carriage part is faulty you need to replace it.
Hope this will be helpful for you. Best regards,
Source:
Dec 18, 2008 | Canon i80 InkJet Printer
Paper not loading, sericr eror message 5100
Dear kamal,
Error code 5100 also come with LED alarm flashes in Orange/Green 2 times. This error happens when carriage part (carriage unit) is faulty so that carriage part cannot read film encoder properly. As a result, carriage part move on uncontrolled. But,in some cases, dirty film timing **** strip (Horizontal film encoder;available only in i series and above) may cause the same symptom. Try to clean film encoder by wiping it with moistened clothe first.
Remedial action:
  • Replace carriage part
  • Clean/replace film timing **** strip
Oct 31, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
124 people viewed this question
k24674
jasbo
jasbo
