Question about Maytag Washing Machines
Cold water during fill cycle appear to be just a dribble.....like no water pressure, except the actual feed hose has plenty of water pressure..... Is there a water screen that needs cleaning?
  • lancastersma Sep 03, 2010
    Is there is in-bound water screen on a Maytag washer just inside the coupling that might be partially plugged causing such low inbound water pressure appearance......?
  • 15,935 Answers
Yes - turn off the cold water valve - and remove the hose at the machine. There is an inlet screen here that gets clogged with sediment.
Thanks!!
Posted on Sep 03, 2010
  • Maytag Master
  • 3,361 Answers
Yes there is a screen or 2.
Turn off the cold water supply.
Remove the cold water hose from the faucet and the machine.
There is a screen in the water valve that must be removed with a straightened paper clip and cleaned.
There may be screens in the hose too.
Some have them,some don't.
  • steve
    steve Sep 03, 2010
    I will need a model number from the washer to be more specific.
    All washers are created different.
What would cause a GE Harmony washer to fill too slowly? The water in cold water wash cycle literally just dribbles into the tub.
The filler hose has a wire mesh filter in it to keep the inlet water from passing particles that would keep the solenoid valve from closing completely. Shut off the water and take the hose off from both the faucet and the washer. clean the screen and check the one in the washer too.
Feb 15, 2018 | Kenmore Washing Machines
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
My Whirlpool Front Load washing machine "sings" during addition of water during some portions of the cycle. In other words, when adding water to the machine, a high-pitched sound is produced...
The chances are that this is one of the rubbers in the inley valve vibrating at a high frequency as water rushes past it. Usually the result of high water pressure, though occasionally low pressure (But I would expect you to describe that as a low humm, so lets presume the pressure is a bit high).
Your machine may be cold fill only or hot AND cold fill. The chances are highest that the COLD feed is the issue (Hot water is usually at a lower pressure) so start there.
Try reducing the pressure to the feed, if you have no specific way of doing this, then simply go to the isolator valve where the feed pipe to the machine meets the plumbing and slowly turn it off. as you turn the lever on the valve, the noise will probably reduce long before you have actually isolated the water supply completely. Leave the isolator valve lever in that position.
Jul 19, 2011 | Washing Machines
Hoover 700l Cold water is not fillingproperly. Only a verey small dribble comes into the machine. I have reversed the hot and cold hoses, making sure that the setting is on "hot". Problem...
Clogged screen in fill valve on cold side. Remove hose from cold side on valve. Pull screen out. Wash under hot water, and re-install.
Jan 23, 2011 | Washing Machines
My washer will not fill with water or do any functions when i turn the dial
My Hoover 7700l ...on "fill" cycle, the water dribbles in. Takes hours to fill so we use buckets to reach the required level.
Tried: Swapping cold and hot water inlet hoses, making sure that dial is in "hot". This solved the problem for filling, BUT when "rinse cycle appoars, it's back to the dribble again.
any ideas?
Jan 23, 2011 | Maytag LSE7806A Top Load Stacked...
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
After using my machine for 6 years and one year at this house - it suddenly won't fill up with water. The pressure at the tap seems fine without the hose cvonnected - but it's just dribbling into the...
at the hose end by the washer there are screens inside the water valve , use a small screwdriver to remove the screens, wash them and put them back in reconnect hose and that should do it.
Sep 07, 2009 | Washing Machines
Kenmore washing machine does't fill with water only dribbles
Try disconnecting the hoses from the rear of the machine and see if the screen filters are clogged up and also make sure that their is plenty of preasure and volume of water when you turn on the hoses unhooked directed into ther drain. This is likely your problem as it is unlikely both the hot and cold fill valves went or bad out at the same time.
Dec 20, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer: no cold water
easy way for me to determine problem is reverse the hoses on the machine still no cold??? should be no hot now!! in which case you have a bad water valve no cleaning need to replace
Mar 01, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
