Question about Mitsubishi WD-52525 52" Rear Projection HDTV
FMT board Thanks for the help on the 52525. Can you give me an idea of where I can get more info on the FMT board? I have some soldering experience, just would have issues identifying the 1000uf capacitors that needed replacing - as well as finding a source for the capacitors.
  • Mitsubishi Master
  • 8,617 Answers
You can get the complete service manual with the disassembly instructions at the following link. They will email it to you after purchase and they also provide free one on one tech support to help you step by step do the repair and they also sell the capacitors that you would require. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 11, 2008
How to replace the dm in wd-52525
The DM is the second board inside the Chassis block directly underneath the FMT board. But replacement DM boards if still good are very expensive your better off replacing the 4 capacitors that fail on the DM.
Apr 03, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Blinking "Timer" light for WD-62725
If this is a DLP, you may have problems on the FMT/DM boards in the sealed electrical chassis.
That's a big problem, because Mits doesn't make the DM/FMT boards available anymore. They are only available for rebuild from Mitsubishi and other qualified places.
There is a chance that there are some vented capacitors on the DM and FMT boards you might be able to replace, but it's for someone really comfortable with completely disassembling a set, soldering in 8 new caps and rebuilding the chassis.
Rebuilds will run you $400-$500 in rebuild costs and an additional $200-$400 in labor, depending on the joint.
Jul 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mits WD-52525 random 1-pixel jitter
if you are a profetional replaced all capacitors on FMT and DM board.. or replaced the chassis........
DM and FMT board N/L/A .........
Jun 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 picture problem
you didnt mention which two boards you replaced the caps on however each board in the chassis has the same capacitor issue. Sounds like you need either of the four V26 Repair kits. The FMT repair kit, The signal Repair kit, The Terminal 1 or the terminal 2 repair kit
Jun 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Whats with my tv?
Good Day;
Replace all caps that are swollen, but resolve your checker pattern:
1. Tile or block pattern replace D8F00 and D8F01 part # 264P828010, also replace C8F26 and C8F29 part # 141P148000 (1 uFD, 25 V) on the FMT PCB (part # 930B924002).
The diodes have a stripe (line) that is the cathode, at one end of the device, the board will reflect that line. Good Luck, big IRISH. PS ; De solder as best as you can, glue is under part, heat one end, while prying up, heat other end. It will come off with moderate to mid high heat.
Sep 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Good Day, Joe;
Suspect the formatter board, FMT PCB, it is not available through the factory though, it must be repaired.
On the FMT check D8F00 and D8F01 part # 264P828010, also check C8F26 and C8F29 part # 141P148000 (1 uFD, 25 V) on the FMT PCB (part # 930B924002). This Avery common problem.
Good Luck, Big Irish.
Jun 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mit 52525 from blinking green light to still green light.
bad capacitors 1000uf on the PWB, FMT and DM boards will cause those symptoms. All capacitors 9 in all need to be replaced
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture on any device/input
The FMT board has 3 bad 1000uf capacitors that need replacing. Let me know if you need more info on the TV.
May 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green blinking light
the PWB , FMT and DM boards all have capacitor issuses with that chassis. If the power light is blinking there are 4 1000uf capacitors on the DM that need replacing. If you need more info let me know.
May 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52 in.... Problem:
Its the board that the rectangular board with the inputs plugs into.its on the right hand side of the chassis.
Mar 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
147 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
