Question about Danby Heating & Cooling
Hi, two days ago I bought a Danby Premiere DPAC13009 portable AC unit. It worked on the first day reducing the temperature from 32C in the room to 26C in a few hours. Although now there is no cold air coming out of the AC and only the fan is working. I verified the two hoses and the exhaust is working good, lot of air is blowing out. Although, no air seem to be sucked in from the intake hose. I checked and I don't see any obstruction. Could the compressor be dead already??? thank you
  • 24 Answers
Comperssors have a thermal overload. If there is a starting problem or low on freon the conpressor will shut down until cooled off. Try restarting and listen to compressor.
Posted on Sep 03, 2010
Portable ac Danby Premiere DPA110CB5BP spitting water while it fans.
If you are referring to the unit doing this on the outside of the structure, this is normal. the "Hamster Wheel" is designed to carry a small amount of water and create a light amount of water to go onto the condenser to help with the evaporation and cooling process. If this is on the inside of the structure, the unit may not be level or another issue causing improper drainage.
Aug 01, 2017 | Danby Heating & Cooling
I need to purchase the remote control for Danby premiere dpac13009 Where I can find it ?
Ebay, only 1 available. $55 free shipping.
NEW Danby Premiere Room Air Conditioner Remote Control Transmitter A2529...
Appliance Parts Pros. $48 + shipping. I would call first because they don't have it in stock. Claim of 5-6 days may not be correct.
http://www.appliancepartspros.com/danby-dpac-remote-control-a2529-950-ap4556076.html
Repair Clinic $49 + shipping. Again call first because they don't have it in stock.
Remote Control A2529 950
Jul 27, 2016 | Danby Premiere 13,000 BTU Portable Air...
I have a Danby Premiere mobile ac unit and it has been working just fine, as of yesterday it all of a sudden just quit working. I can plug it in and it will run for a few seconds and then quit. once i
Hi There,
I would like to help you with this but I need some more information.
Is the display showing any error codes?
Is there a red light blinking?
From what I have learned from a technician, with the weather being so hot and humid in most areas it is likely that the water bucket is full.
If this is not the case, please either respond to the questions above and I will look into this further or you can contact our Customer Service department at 1-800-26 Danby for assistance.
Thanks!
Jul 18, 2012 | Danby Premiere Series DPAC12010H 12,000...
CAN I PUT THE EXHAUST TUBE INTO STORAGE CLOSET INSTEAD OF PUTTING IT IN A DOOR GOING TO THE OUTSIDE?
I think you are asking about a portable air conditioner, not a de-humidifier. With that assumed, the answer is, NO - that is not a good idea. The exhaust tube is for getting rid of the heat that you have pulled from the room you are cooling, plus the extra heat that the device itself creates. This is a considerable amount of heat, which will quickly heat up the closet and leak back into the room you are trying to cool. If the closet it tightly sealed, the unit will not be able to push the air through the tube, and the unit itself will overheat. The result will be that you will be buying electricity to actually RAISE the temperature of the room you are trying to cool.
Jun 05, 2012 | Danby Premiere 12,000 Btu Portable Air...
The portable air conditioning unit turns to air conditioning mode to fan mode and back every 5 to 10 minutes. Is this normal?
Yes, Nicole it is. If the room is cooling down like it should. It actually is saving you money. As the compressor uses more energy than fan.
Hope this helps you.
Jul 14, 2011 | Danby DPAC13009 Air Conditioner
We bought the danby Premiere DPAC 13009 for our trailer and it is blowing the breaker.
check service tag on unit what is the amp rating on the unit does it exceed your breaker size??
Jul 03, 2011 | Danby DPAC13009 Air Conditioner
THe unit has only changed the temp from 89f to 86f in a medium size room ???
The portable AC units have a limitation when it comes to cooling a larger area, Since the unit is meant mainly to be focussed to an area it cannot be compared to the split unit or the window unit where we have the heat exchange exitting into open air. In the indoor unit the heat exchange also happens inside the room contributing to the reduction of efficiency. i would like to advice you to keep the unit closer to the exit or window. try to reduce the area by a false curtain and see if the result is good. Also make sure your filter is clean and the water is drained off.
If this makes a diffference reduce the thermostat settings to allow it to shut off and start again to prevent blocking. The AC should work bettter. Good day
Jul 12, 2010 | Danby DPAC7820 7,800 BTU Portable Air...
Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Jul 10, 2009 | Danby Portable Air Conditioner
Will not cool
I bought the same unit yesterday and took it back today. Not sure what's wrong, I guess they are junky a/c's.
Jun 10, 2008 | Danby Portable Air Conditioner
Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
May 18, 2008 | Danby Portable Air Conditioner
Heating & Cooling Logo
283 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
