My computer keeps saying it does not recognize the printer. And that it has mal-functioned.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    ok..let's begin with introducing our experts to both of your designs, shall we? make and model please.
  • 62 Answers
Try another printer cable - usb / lpt 1
Posted on May 11, 2008
Printer keeps saying busy printing another document
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
Plz guide this machine gives me an error mal function what is mal function
What is the malfuction code showing on the display? This code will be a letter followed by 4 numbers. Such as C3542. Reply back with the code so we can assist you further.
Feb 08, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
I MOVED RECENTLY AND DID NOT TAKE THE PRINTHEAD OUT OF MY PHASE.iT WILL PRINT A TEST PAGE BUT WILL NOT PRINT FROM MY COMPUTER WHEN COMMANDED TO. HOW DO I CORRECT THIS.
If the test page prints correctly this suggests the problem is not with the printer but with communication to the printer. Be sure to check connections.
You did not say how your printer is connected to your computer.
You may want to review page 20 of the Setup Guide which describes your various connection options. If connections appear ok you may want to disconnect your printer, delete your printer from the printer menu, power down, reconnect the printer and then power up your computer to see if recognizes the printer as a new device and proceeds through the install. You may need to use the Add a printer function if it is not recognized.
Hopefully this helps resolve your issue.
Jan 16, 2011 | Xerox Phaser 4400DT Laser Printer
I've encountered an Incorrect Yellow message upon turning on the printer HP2820
The printer would only display messages of functions commonly as ink shortages. For example, color printers with encountering ink shortge would display a message. However, continuing to print would produce least impressive cooration where for multicolored characters tend to appear in yellow. Also, printers with ink malfunctions require inspection of cartridges, ribbons, and compartments for mal alllignments. Readjusting the ink compartments would request performing test print sheets as reallignment check. At which situation, a continued malfunction would be detected as diagnosable by computer popup messages. Refer to the printer user guide. Good luck
Jan 11, 2011 | HP Office Equipment & Supplies
I've plugged in my usb from my printer and set itbut my printer is saying that there is no computer connection
Is the power on both the computer and the printer?
Try other usb ports on the computer, in case one of the usb ports is not functioning correctly from a hardware point of view.
Usually, on hp printers, if you plug it in, it will be recognized by the Windows 7 computer.
What operating system are you using? 7, Vista, XP?
Also, do you have automatic updates enabled for your operating system?
Jul 14, 2010 | HP Officejet 4315v All-In-One InkJet...
Dell a920 printer not recognized by computer
Did you install the drivers. If so goto divice manager and enable the divice.
Sep 17, 2009 | Dell A920 InkJet Printer
After refill the inkt cartidges, because of mal, how can I reset te printer
the simplest way is to unistall the printer and reinstall it once again
May 28, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Computer won't recognize a replaced ink cartridge
This is what worked for me today..
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button until "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semi full Reset" is displayed.
5) Press OK.
Now, check the functionality of the All-in-One. If the issue persists, please perform the next troubleshooting steps
Courtesy of Joe at HP via an email
Oct 03, 2008 | HP Photosmart C6280 Printer
Playback mal-function
TRY A CLEANING CASSETTE THIS MIGHT PROLONG THE AGONY. HEAD IS DIRTY OR NEEDS AJUSTED
Jan 09, 2008 | Canon ZR85 Mini DV Digital Camcorder
jasbo
jasbo
