Question about Whirlpool Duet GHW9150P Front Load Washer
How do we access filter for solving a F2 code?
  • 259 Answers
Remove your lower front access panel by removing the three screws all the way at the bottom. I like to slide the machine forward and tip it back if it is not installed on a pedestal already. This makes it a little easier.
After removing the screws the panel will drop down and to be removed.
Your pump in in the bottom of the machine in the center and there is a clean out handle on the end facing you.
BE prepared to catch any water left inside the machine as you remove the cleanout.
Good luck with this!!
Posted on Sep 03, 2010
Dehumidifier wont turn on or reset. code comes up as F2 and wont reset. Cleaned off filter. no help. any ideas you have would be appreciated.Just bought it last year. we have the hose connected to a...
To figure out what Code F2 is, I took a look at the Owners Manual for the Model # AD70USS, Strangely, the Owners Manual doesn't list an F2 Code or any codes for that matter. Because that model number humidifier, does not have an LED screen.
Never the less, to reset your unit using an alternate method. Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 12 - 15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON and the dehumidifier should have reset itself. If it doesn't check the positioning of the water bucket, to make sure it's contacting the safety switch. Eventhough, you're using a drain home, it's still important.
Hope this helps you solve the problem.
May 08, 2011 | Whirlpool AD70USS Dehumidifier
Washer is flashing f2
F2 on a Whirlpool Duet means their is a problem with the Drain Pump or Drain Pump Filter. The Drain Pump and Filter are located at the bottom of the Washing machine. You must remove the front, bottom panel to gain access to the Drain Pump and Filter. Disconnect the Filter and Drain Hoses and clear them out. If they are clear, you may need to replace your Drain Pump.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Light flashing after two minutes f 4 keeps showing
Hello there:
F4 error code - Similar to F2 but this time the dishwasher is specifically detecting a drainage fault. The drain pump might be malfunctioning but again, cleaning the filters and unblocking the drain might help solve the problem and is a good troubleshooting measure.
Jan 31, 2011 | Whirlpool Dishwashers
Stops cycle reads suds or F2
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. "Sud" code flashes 4 minutes after the pump is turned on and 4 minutes later "F02" flashes. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter from the pump housing by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Nov 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F2 will not come on kenmore elite gas
F2 is related to the pump or your pump filter has become clogged. Depending on how comfortable you feel with doing the repair yourself you can try cleaning out the filter area first and see if that solves your problem.
First and foremost remove power to the unit by unplugging.
On most models you will need to remove the lower cover on the front for access. Be ready with a shop vac, buckets, etc. to catch any water that is in the tub or in the lines. Once you remove the front cover you will see the access to the cleanout. SLOWLY unscrew the access sucking up or disposing of water as you go and eventually the water flow will stop. Once you remove check for socks, undergarments, and other small items (you should be able to shop vac out this as well to make sure). If you find clothing items it is pretty much guaranteed it should solve your problem as long as it has not caused pump damage. Re-assemble completely, and try again. Be sure to properly re-install the cleanout and all parts.
May 03, 2010 | Dryers
What does F2 code mean with the Kenmore Elite HE3?
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
I have a whirlpool duet that flashes f2 and will not do anything, it freezes up and locks up
F2 is an indication of long drain, id try to remove hte lower access panel (3) screws across the bottom front of unit, youll see a filter clean out ( large off-white turnscrew) unscrew snd remove debris from area. be warned there will be water inside hte filter when unscrewed, so UNPLUG UNIT FIRST!!!!!!!!!! and grab some towels first
Nov 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Ar405 error code f2-31. how do i solve this problem
problem sharp AR 405 copier error code f2-31 copier. How do i solve this problem.
Sep 09, 2008 | Sharp Office Equipment & Supplies
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
