Question about BenQ Computers & Internet
ı have got a benq mk2442 television and lcd monitor, when ı open the computer writing no signal and closing monitor. Television is normally working but monitor is not working. What can ı do ?
dodgecharger
  • 254 Answers
SOURCE: BenQ LCD 17 inch Monitor
I wonder if this has a backlight in it. Most/or all LCD flatpanel displays use a backlight in them, namely a small florescent tube (a tiny version of the office florescent lights). If this is burn't out, or the little power supply which runs it dead, you will have a black display. The image is actually there, you just can't see it, except perhaps faintly when external light hits it just right. The display must be disassembled to check this light. If you have tech savvy, and some equipment, voltmeter, maybe an oscilloscope, you could check it out. Where to get a replacement lamp? Google it... perhaps the manufacturer.
Posted on Sep 17, 2007
alxz
  • 89 Answers
SOURCE: BenQ FP731 17" LCD Monitor Problem
Its a problem with the inverter. check the 4 transistors, C5707 near the connectors for the backlight. If none are defective, look for the PF751 FUSE. It sure to be busted.You can replace that with another 3A fuse. Remember, you should only replace the fuse if you are certain there are no busted transistors in the inverter board. Otherwise, you now have a refurbished Benq Monitor
Posted on Jan 07, 2008
viziks
  • 220 Answers
SOURCE: LCD monitor went blank
Which model is it?Does power led remain on?
Samir
Posted on Feb 25, 2008
myob247
  • 1342 Answers
SOURCE: how to get audio from a benq fp767 lcd monitor
You have to plug the audio wire from the monitor into your speaker jack on your computer.
Posted on Jun 13, 2008
Had the compete dark screen problem. Green/amber power light was coming on and off as expected but no image would appear on the screen.
Found PF751 to be open.
Thnaks for the help people.
Posted on Oct 08, 2008
Benq lcd monitor
The monitor requires an input before it can decide what the input is.
Nov 05, 2013 | Computers & Internet
My BenQ FP767 monitor power is on, but the screen is black. my pc is very good.
open back cover of your monitor then adjust the screen control of the flyback to your desired brightness
Joel
Apr 20, 2013 | BenQ FP767 17" LCD Monitor
Benq Q5C3
Someone would have to open the unit and see if fuse bad or even puffed up caps in the power supply for it.
Dec 06, 2012 | BenQ FP731 17" LCD Monitor
Do you know how to open a benq fp91g+ monitor?
Here is the service manual: http://elektrotanya.com/?q=showresult&megnev=BENQ&megnev2=FP91&kategoria=&kat2=all
Most of the time you will use flat blade screw driver, starting at the bottom edge to pry open the case then work your way around, also look at YOUTUBE, just search for HOW TO OPEN LCD MONITOR.
BenQ makes monitors for DELL and HP.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | BenQ FP91G+ Monitor
Benq 19' LCD Screen 3 yrs old- no signal detected on brand new PC
Have a look at the back of your computer.
See if there is more than 1 video port.
If there are 2 ports try plugging the monitor into the other port....
Sometimes motherboards have internal video cards, in this case the video port is in among the USB ports, sound and mike sockets etc.
Look for a video port away from all those other things.
Apr 26, 2009 | BenQ FP71E 17" LCD Monitor
Benq FP731 LCD not start up, only green power lamp
Opening it will not likely solve your problem. Have you tried another monitor on the computer to see if the problem may be with the computer itself?
Mar 04, 2009 | BenQ FP731 - 17" LCD Monitor
Weak or no Signal issue when connected to my TV.
Yes weak signal. Also closing the laptop lid puts the computer in sleep mode.
Jul 07, 2017 | Digital Lifestyle FA1B32Z 32 in. LCD...
Computers & Internet Logo
49 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
