Question about Ovens
THE GE ELECTRIC OVEN SHOWS FO and beeps. I had to cut the power off to the oven to get it to stop. What should I Do?
  • 1 more comment
  • rushford Sep 03, 2010
    I figured it was bad. Question, oven is ten years old+ and we hate it. What about a replacement? A good brand to relpace with?
    Thank you. Have a great weekend.
    Very good. The follow-up was fantastic.
  • Ovens Master
  • 11,800 Answers
Call a repairman, its mainboard has died and must be replaced. It will be expensive, over $250, so be prepared.
Posted on Sep 03, 2010
  • Azrael SRL Sep 03, 2010
    Yes, replace it, finding parts for such an old unit will be impossible.
    I'm using Electrolux and in the 2 years since i have it it has worked perfectly. Westinghouse and GE are also very reliable - yours has lasted 10 years. Just pick the one you like and remember that the price is a good indicator of the quality. Stay away from those made in Asia or south America.
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 | GE Ovens
Oven beeps and shows F7.
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on
thanks.
Sep 29, 2010 | GE JGRP17 Gas Single Oven
My oven has code Fo displayed. It began with a beeping. We turned off the breaker and turned it on again. The beeping continued. After several attempt the beeping has stopped but the code remains...
Hello, I had the same FO error. It turned out that the ribbon cable from the front panel was not making good contact where it mated with the circuit board. Remove ribbon cable and clean contacts on ribbon cable. Replace cable and problem should resolve.
Thanks
Jul 14, 2010 | GE JGRP17 Gas Single Oven
My GE Profile oven is beeping every minute. I've
if its an f-7 error code its due to a stuck error code
Feb 06, 2010 | GE Profile JT955 Electric Double Oven
The F7 alert keeps flashing/beeping on my JKP27 GE electric double oven even after clearing it or cutting the power to the oven for a period of time. Any suggestions? Thanks!
Ya either have a stuck keypad or a bad oven control. To see what it is you push the clear/off pad, disconnect the ribbon from the control and wait 32 seconds, to see if the if the F-7 code occurs again, If it don't then bad keypad, if it does then bad control.
Jan 28, 2010 | GE JKP28 Electric Double Oven
The upper and lower oven will not turn on there is power to it and clock and oven lights work there is an FO red light that comes on and beeps and flashes
Built In Oven Fault Codes
F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Sep 21, 2009 | GE Profile JTP56 Electric Double Oven
GE Profile oven beeps and displays FO
Your electronic oven control(clock) is bad and must be replaced.
Sep 02, 2009 | GE Ovens
The oven controls are not working. then FO shows
If your appliance is newer than 1996 F0 error code is a stuck key pad .
To verify turn off power and access the control panel and remove the ribbon connector that goes from key pad to control board .
Now restore power.
If the F0 code goes away you'll have to replace the key pad .
If it stays it means the control board is bad.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 11, 2009 | GE 30" Built-In Single Electric Convection...
My GE oven wont stop beeping it has an FO on the screen. All the buttons will not press. I just bought the house and have no idea if its done this before. Please help!!!! Chelsea
F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Dec 12, 2008 | GE Profile JTP18 Electric Single Oven
JTP56 Double Oven Beeping and Display FO Code
http://www.fixya.com/howto/h155060-dreaded_f7_error
May 18, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
66 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
