Question about Poulan Weedeater/Electric Trimmer 4.1 Amp
5/8 OR 13/16 WRENCH WILL NOT FIT, WHAT SIZE DO I NEED FOR POULAN WEEDEAT. IT IS LARGER THAN THE 5/8, BUT SLIGHTLY SMALLER THAN 13/16
    President:
  • Poulan Master
  • 1,545 Answers
Maybe try something metric or 3/4".
Posted on Sep 03, 2010
Troubleshooting chainsaw
Sadly, the 3816 is not designed for larger timber. 38cc is only for smaller limbs, As a general rule also the largest timber to cut should only be 2/3 of the length of the bar
Jul 27, 2014 | Poulan/Pro 3314 3416 3816 3818 40184218...
Need to fine out if it would what other size of belt you can use on 38 inch cut on poulan riding lawn mower
Are you asking what size belt to use or are you asking what other size belt, like you want to use one a little smaller or a little larger? If that is the case, what difficulty are you having that you would need to do that? Did you put a Craftsman deck on a Poulan or something odd like that?
Aug 06, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
What file size do I need to sharpen chain
It realy depends on the type of chain you have fitted, hobby chain fitted to small home owner saws is normally a 3/8 low profile and requires a 5/32 file, slightly bigger machines have a .325 chain and require a 3/16 file, big machines have a standard 3/8 chain and require a 7/32 file, the correct file should fit nicly into the cutter and sit slightly abobe, this will stop you file under the cutter head and creating a hook.
Feb 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do you adjust the size [eg, make it larger] of a scanned print,for a final print,for a Umax Astra 1220U
Scanner will scan actual size only. If you need smaller or big sized print, select appropriate size and use 'fit' command before printing. With Raster Editing software, you can create another Image which is smaller or bigger.
S. Mohan
Sep 03, 2010 | Office Equipment & Supplies
What size speakers do I have in my mercedes benz E400?
I'll assume you don't have the Bose system, or else you wouldn't be looking for new ones, depending on your year. It's either going to be 6-1/2" or 6-3/4" The most popular speaker size — replace your factory speakers with some 6-1/2" car speakers for strong bass and improved clarity. Many models includes brackets that allow them to fit in slightly larger 6-3/4" openings. The 6-3/4" speaker, the largest round car speaker, fits in an increasing number of newer vehicles. They offer more cone area than the slightly smaller 6-1/2", so they add more bass to your system.
Apr 07, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
Zenith 32" TV picture is larger than the TV screen size.
Adjust the Aspect ratio. The manual will tell you how.
Feb 02, 2010 | Zenith A32B84R 32" TV
I need to change the alternator on a 2001 ford focus and need to know what size wrench is needed to loosen the timing belt tensioner enough to remove the timing belt. Please help
I don`t know the size,but it will be metric.If you have a standard,american set of wrenches,get the one that is closest to fitting the bolt head.Here is something to help you decide what the actual metric size wrench to use.8mm is 5/16,,,10 mm is smaller than 3/8.11mm is a 7/16.12mm is larger than 7/16 but smaller than 1/2.13mm is 1/2,14mm is 9/16,15 is bigger than 9/16,but smaller than 5/8.,,5/8 is 16mm.17mm is 11/16,18mm is bigger than11/16,but smaller than3/4,19mm is 3/4.I hope this helps.
Oct 30, 2009 | Ford Focus Cars & Trucks
Cannot find the replacement cartridge for my HP Photosmart Plus B209a-m printer. The black (564) cartridge on HP site is for the smaller cartridge. I can find the smaller (564) and the 564XL (which is...
Are you using genuine HP cartridges?
According to HP, the two cartridges for your printer are the 564 and the 564XL. Either cartridge will work.
HP does not offer another size.
Take the black one out that's in there now and see what the Part # is... then do a search for it.
Oct 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Boot size fit to board width
8 or Smaller Board Width 24cm or less (Narrow) 8.5 - 10.5 Board Width 24 - 26cm (Regular) 10.5 or Larger Board Width 26cm or More (Wide)
Dec 01, 2008 | Kicker Forum SLR Snowboard Boots
Poulan Weedeater/Electric Trimmer 4.1 Amp Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
