Question about Whirlpool Dryers
How do I know if the heating element has gone bad?
    President:
  • 3,074 Answers
Remove the vent tube turn on dryer feel for hot air, you can also take the front panel off and open the top of the dryer and look at to see if it is brunt in half Hope this helped Tim
Posted on Sep 03, 2010
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: wont heat up. if the thermostat has gone bad will
Hi texasjul4...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on Jul 20, 2011
Hi, heating element gone I assume. It works well but does not heat up anymore.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Mar 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
E63 code
E63 is for a open heating circuit. could be a problem with the heating element or a sensor gone bad. Check to see if your dryer is under warranty. If it is I suggest you have the manufacturer take care of the problem. If not let me know, and we'll start by checking the heating element.
Feb 23, 2011 | Electrolux EIED55I Dryer
The fan is working in the oven but not heating up
Be good to know if electric or gas but most likely electric. Either the element has opened,(gone bad) or the thermostat has goon bad. Very unlikely that the temperature rheostat (knob to set temperature on stove) has gone bad. But check the elements first.
Jan 17, 2011 | Ovens
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Whirlpool model LER7648PQ1 won't heat up
There are a few possibilities- I'll take you through them:
1) Most probable: your heating element has gone bad- actually they usually break when they go bad/burn out. This will likely require some skill and some instructions for you to repair- plan on replacing the heating coil and the door seal for good measure, especially if the unit is more than 5 years old.
2) Less probable but possible: are you sure your drum is tumbling? if not, your clothes won't dry and you'll lose the element in short order.
3) yes less probable but still possible- the contacts on the switch dedicated to heat settings or the thermostat have gone bad, denying current to the heating element.
Good luck!!
Dec 14, 2009 | Dryers
Dryer won't heat
1) Most probable: your heating element has gone bad- actually they usually break when they go bad/burn out. This will likely require some skill and some instructions for you to repair- plan on replacing the heating coil and the door seal for good measure, especially if the unit is more than 10 years old.
Good luck!!
Dec 11, 2009 | Frigidaire Dryers
The centre element in my 4 slice model has gone. Can this be replaced?
Don't know if you can get the heating element as separate part. But, this can probably be repaired. It's likely either a burned connection/connector or the heating element is broken.
Bad connectors can be replaced, the heating element can be just twisted back together where it is broken.
Charlie
Aug 14, 2009 | Dualit CTS4E 4-Slice Toaster
Indesit washer dryer, washer is fine, but dryer does not heat up
If you don't hear the fan running then the fan motor has gone bad. If the fan motor is bad then most likely your element has burned out. If you hear the fan motor than probably your element has gone bad..
Jul 29, 2009 | Splendide 2100 Vented Washer-Dryer
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
My dryer will not heat up
most commonly its a fuse, but it could very easily be the heating element. but more tro the point, this is a site for computer problems, not anything else problems. for this kind of thing look up the manufactors' website for a phone number to contact. then ask them the problem. incidentally, if the element has gone, throw it out and buy a new one, as the element will cost you more than the rest put together. silly, but true.
Jun 20, 2008 | Computers & Internet
Dryers Logo
161 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
