Question about KitchenAid KUDI01TBK Dishwasher
My kitchenaid dishwasher is not working properly. The light above the button that says "Rinse Only" is flashing and there is no way to stop it or turn the dishwasher on. How can I fix it?
SOURCE: I can't get my dishwasher to start
Part Number: 99002254 you may need this part depending on model no
SWTCH-DOOR 99002254.jpg View Larger Image
Posted on Jun 02, 2008
  • 9 Answers
SOURCE: KitchenAid model KUDM01TJ
Check for loose wires on all switches and their is a fuse on the electronic panel that should be checked.
Posted on Aug 31, 2008
  • 56 Answers
SOURCE: the light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
Posted on May 31, 2009
erpaalai
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
SOURCE: My KitchenAid dishwasher (KUDS25SH) start and stop
MY KUDI25 CHWH1 has the exact same problem...I'd love to hear about a fix!
Posted on Mar 01, 2010
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
Clean light flashes on my KitchenAid KUDS01DJ and it wont run
My dishwasher did the same thing. The repair guy fixed it and told us how to reset next time it happens: press: Hi temp then Energy saver then Hi Temp then Energy saver do this quickly over 5 seconds all the lights should come on Then,turn off the breaker for one minute then, go back to the dishwasher and press cancel. All the lights should turn off. Start dishwasher as usual. If the cause was just a brain fart, the dishwasher should work.
Jun 03, 2010 | KitchenAid KUDS01DJ - Multiple Color...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Kitchenaid superba kuds01ijbs0 rinse only light flashes
Hi there.See if you can find the reset button.If you can't find that unplug it and plug it back in to reset.That should fix the problem
Apr 01, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
Flashing clean light and wont start. Is there a sequence of buttons to reset the switchboard?
sani rinse---heated dry---sani rinse---- heated dry.. all the lights on console should light then close the door, let run for 20 -30 secs, and cancel the cycle, if the problem happens again yo need t call a servicer. 1 time maybe a fluke but to happen again indicates a heating, issue somewhere(or a lack of heating)
Mar 04, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
////////////////////my kitchenaid dishwasher lights are flashing
Can you explain the issue in detail - is your dishwasher not working at all, or the buttons continue to be lit up, etc?
First and foremost, check the dooe switch to see if it is functioning properly.
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchenaid Dishwasher KUDS24SEWH?
This problem was aparently classified under the LG dishwasher / LDF6810ST section, I don't think this problem got looked at by KitchenAid gurus.
Were the problems resolved?
Sep 24, 2008 | LG LDF6810ST Stainless Steel Built-in...
Open Questions:
KitchenAid KUDI01TBK Dishwasher Logo
53 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
