Question about Maytag 19 cu.ft. Top Freezer Refrigerator MTB1954
I have maytag freezer MTB 1894 AR. Top freezer accumulates ice and it stops cooling inside lower section. It starts cooling again once accumulated ice melts. I am wondering what is the reason and the water from the ice doesnot leak( wher it goes inside the fridge.) Would it be the seal for the top door or a sensor to regulate humidity?
3 Suggested Answers
  • 27 Answers
SOURCE: Concaved out freezer door
If concave is severe you will have to replace door. You can try to alleviate a slight gap by using a hairdryer and blowing hot air on the gasket in the area of the gap....move the dryer in up and down motions and the gasket will expand! Just make sure that there is no ice pressing against the door inner first! Oshie
Posted on Jun 26, 2007
SOURCE: Ice accumulation
Solved.
Posted on Jun 25, 2009
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
MY MAYTAG REFRIGERATOR MODEL #MBF2254HEQ IS FORMING ICE UNDER ONE OF THE VEGETABLE BINS. THERE IS AN ACCUMULATION OF WATER THERE AND THEN IT TURNS TO ICE. WE HAVE TRIED LOWERING THE TEMP BUT THAT DOESN'T...
Make sure that the compressor is cutting off at the set temperature and is not cooling beyond.
If Ok then the second part is the leak, check if the condensation is happening into the vegetable section, isit due to constant use, the door is open . now make sure that the tray is cleaned and put on once again to check the water collection.
Look for leaks , if so plug them but it can be condensation, set the fridge temperature lower and make sure the freezer frost is not coming over.
Sep 25, 2010 | Maytag Refrigerators
Leeking water inside fridge from top
Defrost drain is clogged. This accessable thru the back wall of the freezer. Also depending on your model some also have removable Bottom floors of freezer that also get ice accumulation. When the defrost drain gets clogged water from the defrost cycle has no where to go so it stays and accumulates ice till eventually it leaks into the fresh food section. Clear the drain completly and you will have no more problems.
Feb 02, 2010 | Freezers
Water accumulation inside the bottom of the frig
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 31, 2009 | Refrigerators
Ice accumulating in the bottom of the freezer
blower may not be working as efficiently as it should cause bad circulation of the chilled air.
Jun 27, 2009 | Maytag MFD2562KE Bottom Freezer French...
The freezer is accumulating frost. i have
Some models like yours came with a defrost control board and others came with a defrost timer. They should be found inside the fresh food compartment and behind the temperature control panel. You will need to inspect and let me know which you have. Unplug first. If the control board looks or does not look burned it could be bad. The timer can be turned clockwise until compressor stops and should remain stopped for about 25 minutes. and then turn itself back on. If these look good then we need to remove the rear panel inside the freezer and test the defrost element with one wire disconnected to check for continuity. Just to be sure the element has not burned out. The defrost thermostat is connected to the defrost element and will have open contacts inside it above 50 degrees. Do these test with power unplugged and let me know what you find. Sea Breeze
Jun 21, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
May 10, 2009 | Refrigerators
Refrigerator and freezer not cooling/freeding
Possibly a defrost circuit problem -
1) Bad defrost thermostat
2) Bad defrost heater
3) Bad defrost timer
4) Failed evaporator fan motor.
Look for frost accumulated inside the louvers at the back panel, top and bottom. If you see it, remove food from freezer and put in ice chest. Take out shelves, get hair dryer and warm the backside of the freezer, directing air down the louvers. Then leave to sit for 4-6 hours with the freezer door open. Put towels in the bottom of the freezer to catch any melted ice.
After period of time, plug unit back in and power the unit back up. Once you know it's cooling, empty ice chests back into freezer.
If there is a problem in any of the above components, then it will show up in 3-4 weeks witht he same problem again.
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
I am accumulating ice inside my freezer
It needs to be defrosted. If ice builds up quickly again then start shopping for another freezer as the repair is not worth it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 21, 2008 | Freezers
Whirlpool freezer and the refrigerator.
Chances are your defrosting clock is stuck or quit working.
The clock works as timer to set time for defrost, at which time it stops the compressor, and turns a heater tube next the cooling coils to melt ice. It depends on your expertise if you want to try replacement,as most replacement are universal, and some rewiring is sometime involved. The clock is usually in front at the bottom behind the removable grill, or in the back. It looks like a square box with a dial that has a one way turn knob. To check use flat screwdriver to slowly turn dial (you can only turn one way) until the compressor stops, then wait to see if compressor starts back on it's own (it might take as long as 30 min.).
If it does not start it's bad and need replacement. Of course you can turn dial again until it starts again so you can use fridge. If it does start it could still have been the problem where the clock got stuck, and you got it going again by turning the knob, but let it run. If it works for a while and then have the same problem again the replace clock.
Hope this helps you
Dec 12, 2007 | Whirlpool (ET8FTEXSQ) Top Freezer...
Refrigerators Logo
281 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
