Question about PSC QuickScan 6000 Plus Handheld Barcode Scanner
Just purchased a gas powered flowtron log splitter, cylinder cycles good but no power. Any suggestions?
I have a 45 ton Grudge Log splitter. the ram works but has no power to split logs.
indicates insufficient pressure from the pump
bypass at the ram/piston seals---seals or scored cylinder
have it checked by a hydraulic specialist
Nov 12, 2016 | Tools & Hardware - Others
Works for 15 min and then ,the ram moves to log and stops,checked fluid ok, voltage 115 ok
My thought is that there is air in the line. I had problem like that with my splitter. To cure it I had to stand the splitter on end because the oil fill is at the wedge end. I filled it. set it back horizontal and cycled the ram full length 3 times. I stood it on end again and could add more fluid. When I filled again it was now full of fluid and works properly. It also could be that the splitter is not powerful enough to split that size log down the middle. I must take a smaller bite then it works.
Dec 13, 2015 | Earthquake 5 - Ton Electric Log Splitter
Was working fine until just not enough power to split log
Air conditioners usually cannot split logs very well. They are better at cooling instead of splitting wood. If you have a wood splitter and picked AC by mistake then I would check the hydraulic fluid level, grease the slide that the splitter wedge runs on. Then change the oil in the engine and clean the airfilter or replace it. Also make sure you use fresh gas and not old gas. gas goes bad after sitting a few months.
Aug 15, 2015 | Heating & Cooling
Loss of power in Flowtron electric log splitter
3 things to check. : seals in the cylinder, seals in the valve body and pump pressure regulator.
Jun 27, 2015 | Electric Tools & Hardware - Others
Loss of power
Sounds like either the internal relief on the control valve is bypassing prematurely of the setting or possibly the packing in the hydraulic cylinder is worn and bypassing fluid. Not really enough info to make a good diagnosis.
Feb 20, 2014 | McFeelys Scheppach Hydraulic Log Splitter
Need motor brushes for flowtron log splitter model ds26
Take you brushes to a good hardware store an see if they can match them.
Sep 09, 2013 | Garden
Electric log splitter motor hums but won't run
suggest you get information on repairing log splitter, not dryer. have the same problem, and no replacement parts available. must be in the electrical, easiest would be capacitor, less the motor itself, take apart and see if windings burned, or smell electrical
Oct 13, 2012 | Dryers
Where do I look to find a wiring diagram for a electric flowtron log splitter?Anyone? Please Help...
Your best chance for getting the diagram would be to contact the manufacturer. Refer to any literature that came with it.
I tried to find a support site, but to no avail. You might get lucky and find a repair facility that has one, but that would take some serious detective footwork.
Jan 09, 2011 | Sport & Outdoor - Others
I need a replacement spinner assembly for an older Flowtron Leaf Eater -- 800, I think. Any suggestions?
Go to www.flowtron.com. There you can find the parts you are looking for like ler-500 spinner assembly for $20.95.
Good Day.
Nov 18, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
Computers & Internet Logo
130 people viewed this question
Top PSC Computers & Internet Experts
Jax Planet
Jax Planet
Sardar Yasir
Sardar Yasir
Level 1 Expert
Tom Chichester
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
