Question about Toshiba Satellite A70 Notebook
How to boost cooling fans on Toshiba SATELLITE A70 Laptop
    Guru:
  • 1,082 Answers
There is no way to "boost" the fans. I'm assuming the fan runs.
Buy a laptop cooler from a local store. They come with USB fans that will assist with cooling. Also, never use a laptop on anything but a hard surface, never on a blanket or on your lap.
Posted on Sep 03, 2010
Hi there is a toolbar coming up the whole time saying,,,,,WARNING a problem with the cooling system has been detected, please turn of the computer and return for service immediately
Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
Welcome to FixYa! Based on the error you have received, this means that the cooling fan of your laptop needs to be cleaned and checked at. This is a common problem with any toshiba laptop. I suggest checking the heatsink of your laptop. If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
  5. If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Hope this helps! Thank you for using FixYa!
Jul 27, 2011 | Toshiba Satellite 1715XCDS Cooling Fan...
I need to replace my fan for my toshiba laptop, nad need to know how to disassemble the laptop to get to the fan.
Toshiba Portege A100 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A100/remove-systemboard-replace-fan-1.htm Toshiba Portege A600 or A605 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A600-A605/disassemble-laptop-1.htm Toshiba Portege M700 http://www.irisvista.com/tech/laptops/Toshiba-Portege-M700/take-apart-tablet-pc-1.htm Toshiba Qosimo F40 or F45 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-F40-F45/laptop-disassembly-1.htm Toshiba Qosimo G25 or G20 http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm Toshiba Qosimo X305 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-X305/laptop-disassembly-1.htm Toshiba Satellite 1955-S805 http://sites.google.com/site/electrochain/toshibafan Toshiba Satellite 2410 http://mardou.dyndns.org/Privat/homepage_cms.ns5/content/homepage_tutorials_toshiba_satellite_2410_-_luefter_tauschen.html?Open&lang= Toshiba Satellite A35extlink.png http://www.irisvista.com/tech/laptops/ToshibaA35/Satellite-A35-fixing-overheating.htm Toshiba Satellite A60extlink.png http://tech.icrontic.com/articles/clean_laptop_heatsink Toshiba Satellite A105extlink.png http://www.paulstravelpictures.com/Toshiba-Satellite-A105-Laptop-Overheating-Dust-Removal-Guide/index.html Toshiba Satellite P10extlink.png http://loblog.wordpress.com/2006/03/08/toshiba-p10-schaltet-sich-ab/ Toshiba Satellite P305Dextlink.png http://www.insidemylaptop.com/clean-cooling-fan-toshiba-satellite-p305d/ Toshiba Satellite X205extlink.png http://www.irisvista.com/tech/laptops/Toshiba-Satellite-X205/take-apart-laptop-1.htm List of a lot of pc fan repair guides:http://repair4laptop.org/notebook_fan.html
May 09, 2011 | Computers & Internet
We have an older Toshiba Sattelite A70 laptop which is extremly noisy. It also switches off a while if lying down on a flat surface, which means it appears to be overheating. Is this a common problem with...
The noise is most likely an extemely dirty cooling fan. To find out for sure that it's your fan and not your hard drive, take your hard drive out and then turn your computer on. If the noise is still there it's most likely your cooling fan, if not then it's your hard drive. If you don't know how to take your hard drive out or open your computer up to clean it you'll need to take it to someone who can.
Next, you can get a laptop cooler from most office or computer supply stores or any of the online computer parts sites. They range in price from around $10 to over $50. I recommend looking at the descriptions and online ratings, then picking one that best fits your needs rather than going on price alone.
May 23, 2010 | Toshiba Satellite A70-S249 Notebook
Toshiba Satellite a70-s256 fan issues
Instead, turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air.
Give your computer a "blow-job", to remove all the dust that has accumulated inside your computer.
The dust has been acting as "insulation", forcing the fans to run faster, and with more noise.
Cooler computer -> quieter computer.
Jan 16, 2010 | Toshiba Satellite A70-S256 PC Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
I have a Toshiba Satellite A70 laptop.
you can try the memory try one stick at a time. also try the laptop with as little components as possible.
remove the dvd drive, hard drive and wifi card and see if it will boot.
then put each one back in at a time and try it to find the culprit
Apr 24, 2009 | Toshiba Satellite A70-S249 Notebook
Cannot turn on the wieless network device for toshiba A70
There is a switch on the side of your laptop with enables and disables the wireless card in your laptop. Make sure it is on and lit.
Mar 04, 2009 | Toshiba A70-S256 Notebook
Cuts of
Becarefull,
Seems like your laptop is overheating, and it shutsdown as a way to protect the processor.
With a vaccum, **** the dirt that might be trapped in the fan or fans.
This should help.
If not, then you need to open laptop and perform a deep cleaning on the Heatsink, and apply fresh heat release compound on the processor.
Please don't forget to rate this answer if it helps
Nov 10, 2008 | Toshiba Satellite A70-S249 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite A70 Notebook Logo
100 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
