Question about Roper RES7646KQ Electric Dryer
Dryer will not turn off when I open the door. As the light will not come on, I believe the problem is the switch on the door. The door switch assembly can be ordered from Roper, but I cannot find a schematic that shows me how to replace the switch. Can you direct me to where I can find this information? Thank you. Roper dryer model: RES7646KQ2.
    President:
  • 1,218 Answers
Good day,
Sounds like the door switch. Easy repair. Remove the lint filter.
Remove the 2 screws under the lint filter opening. With a screw driver, insert it between the lid and front panel on one side at a time. Pop that end up and then do the other side.
Lift the lid up and away from you.
You will see the switch. Replacing it is a pure nuts and bolts operation. Just make sure you mark the wires before removing the old switch.
The kit (It's a Whirlpool product) should be available at any decent sized appliance parts house.
Posted on Sep 03, 2010
THE LIGHT WILL NOT COME ON WHEN THE DOOR IS OPENED AND THE DRYER WILL NOT STOP WITH THE DOOR OPEN
The dryer has a switch in the door that is activated when the door is opened/closed, replace this switch or check the connector to it or the wiring.
Oct 25, 2016 | Kenmore Dryers
Door is ajar message when shut light comes on but doesnt run
That's because the door switch isn't getting pushed when you're closing the dryer door for some reason or another. Its located at the top of the door. Try pushing the switch by hand and seeing if the light shuts off when you manually push it.
Nov 27, 2013 | Samsung DV337 Electric Dryer
Dryer door open signal
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
Apr 21, 2012 | Dryers
Does not turn off when door is open
The image below shows the wiring diagram for your model of dryer. The door switch is shown in the closed position. When the door is opened, the contact is broken that completes the neutral circuit through the door switch. (I am not showing that your model of dryer has a drum light. If it did, then the drum light would illuminate when the door is opened.)
Based on your symptom, a bad door switch is apparently causing this problem. It is not breaking the neutral circuit to stop the motor from running. Replacing the door switch assembly should fix this problem. NOTE: Be sure to unplug the dryer before accessing any internal components.
Apr 16, 2012 | Kenmore Dryers
Dryer wont turne on but inside light comes on
check the door switch as this switch has 2 positions one for the light on/door open and the other door closed light off and dryer can operate,depending the make & model will determine how to access this door switch
Feb 12, 2012 | Dryers
Dyer suddenly will not turn on
You need a new door switch, if the switch isn't working the dryer will not start.
Jan 29, 2012 | Dryers
Whirlpool model LER8648LW0 - the dryer will not stop when door is opened and the interior light does not light. I have changed the bulb on the light but it still does not work. I suspect the problems are...
I suspect the problem with your dryer is the door switch as opposed to the timer...its the responsibility of the door switch to stop the dryer when the door is opened as well as turning on the light too when the door is opened.
The part number for the door switch is 3406107 it could be purchased at your local appliance parts store or online at;
apdepot.com
repairclinic.com
searspartsdirect.com
apwagner.com
partselect.com
This youtube video will show ya how to replace the door switch http://www.youtube.com/watch?v=gWQhuQXa6d0
GENE
Sep 12, 2011 | Whirlpool LER8648L Electric Dryer
Dryer won't turn on believe it's the start switch,has power,the timer is working and the door latches
if the timer is working and counting down, you need to open the door and spin the drum, if it spins real easy , with no resestance you need to check your belt,, if the belt comes off or breaks it has a micro switch that shuts the motor down, but the timer and lights will still work
Jan 19, 2011 | Kenmore Kitchen Ranges
Dryer will not start,put a new start button,
The dryer is electric? not gas? If so you may have 110 and 1 side and not on the other. Reset the breaker and make sure you have 110v on each hot leg. You say start button I assume you mean door switch for the light? Have you checked the bulb? If this is already yes to this point open the top up and look at the wires coming to the door switch 1 of them is most likely chewed into by a mouse or something. the light has to have power to it all the time the door is open no power no light because I dont believe it gets any power except from the main power terminals not the timer or anything else .
Mar 11, 2009 | Dryers
Kenmore elite quiet pac 9
unplug dryer, then take the top off and check your connections to door switch.i believe this model has a broke belt switch.open the bottom with the machine unplugged and reach inside and see if the belt is broke.if it is then replace the belt.
Nov 03, 2008 | Kenmore Elite HE4 Electric Dryer
Roper RES7646KQ Electric Dryer Logo
264 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
