Back to:
Tags:
VCRs
Generic problem for all VCRs
Changing uhf output of vcr
posted by Easy4Kill on May 11, 2008
How do I change the uhf output channel of my vcr
Comment by Easy4Kill, posted on May 11, 2008
Model is a Sansui VCR955EI
Comment by Easy4Kill, posted on May 12, 2008
it is the channel output i want to change as it is to close to a local tv channel22 and the vcr went to channel23 after a power loss this weekend
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
accordianman
Rank:Wiz Wiz
Rating: 82%, 592 votes
Did you mean "VHF"? UHF cannot be converted externally....accordianman
Comment by accordianman, posted on May 13, 2008
My bad..What country are you in? The US, Canada, and sovereign countries use either channel 3 or 4. Since I am not privy to the operations of other areas, I'll have to venture a guess that the switch you're looking for is in the back of the VCR, close to the RF connectors...accordianman
Rating Locked! (?) Easy4Kill has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Changing uhf output of vcr:
I don't want to Accept this solution
Can you Help with these VCRs problems?
JVC HR-9600U VHS/S-VHS playback VCR
The transport mechanism is not working properly. Do you...
JVC HR-S9500 S-VHS VCR
technics sl-p555. when a disc is inserted you can hear the...
Sharp VC-H800U VHS VCR
I live in Cuba and I´ve been visiting my son last...
VCRs
I have VCRs with NO coaxial connection and TVs with ONLY...
VCRs
My Vcr will not turn on, When i press the on button it...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
