Question about Philips Computers & Internet
Hi, I have a philips monitor serial no: TY 64985283 and messed something up in the menu options that has caused the screen to continuosly scrool like a movie wheel. Can you please tell me how to fix?
    President:
  • 1,851 Answers
I don't know your model so I'll try to guide you without that. Push the OK button and scroll using the up - down of the monitor buttons to go to reset. In case of asking yes - no push ok again and choose yes. Press ok again and exit.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 03, 2010
Hi we have a compaq 7550 screen that when turned on has a red sheen over the whole screen. Any solutions or is it ready to throw away. thanks
You may try messing with the settings on the monitor. The menu buttons are usually on the front. Try to find something that deals with the color tones of the monitor. If messing with these settings doesn't fix your problem, then unfortunately, it is probably time to throw it out.
Aug 27, 2011 | HP Compaq FS 7550 17" CRT Monitor
Solve Your Philips 105S51, 15 in. (White) 15" CRT
Push the menu key on your Philips Monitor and select the option to increase the screen size in the left and right direction.
The picture looks like this
Select it and then use the left and right arrows to either increase or decrease the picture.
Regards
damnor01
Feb 08, 2011 | Philips 105S51 15" CRT Monitor
Screen keeps displaying menu options when that button is not being pressed on remote have to turn off tv to get back to regular viewing or game playing what is making this screen keep appearing
Hi. I suspect that the remote may be the cause. Remove batteries from the remote and see if the menu appears. If it dosent, I suspect the remote may have had something spilt over it and needs to be cleaned out. Hope this helps you out.
Feb 01, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
Approx 40% of right side of screen flickers,non-stop
This problem is normally resolved by degaussing your monitor?.
This option is found normally on the control panel buttons of the monitor. Just press the menu option and look for the Degauss option.
You should have the option someplace on the monitor controls.
It will disperse any magnetic build-up that has taken place on your monitor over time.
Also check for any electronic items if they are placed too close to your monitor as the magnetic field from other items might be the reason for the same.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Jan 05, 2010 | Acer Computers & Internet
Memory recall option is Continuosly blinking on the screen and also brightness option also too..what to do with this problem
This is the exact same problem which I am facing at this moment. I opened the Case of the monitor. I saw that there are 2 small buttons with a extended rod attached which goes into the buttons on the Monitors body. I saw the Contrast button and the brightness and the Menu button are stuck. I also saw that the monitor pads and the monitor sensor board has complete rust. I think I have to change the button pads and the Monitor Board. The same thing I am seeing in your case. I think this is a cause of Excessive moisture content in the air which is causing rust and jamming of Buttons.
I think now you can get what to do.
Thank you Sir, Have a nice day.
Sep 23, 2009 | ViewSonic E70f 17" CRT Monitor
How do i reset my tv to factory settings
Your remote should have a button labeled menu (at least if it's the remote that came with the TV). Press that button. Somewhere in the menu there will be an option labeled "restore presets" or something like that. It varies from TV to TV, so that's as specific as I can get.
If you still have your owner's manual, it should have a breakdown of the menu options.
Sep 19, 2009 | Philips 60P8341 60" Rear Projection...
Monitor keeps displaying model and serial information
@ baller98_199; did you ever get a solution to this? I'm having the same problem with the same monitor!
Mar 13, 2009 | Sony SDM-HS75 17" LCD Monitor
Monitor turns off and is dim
replace pwr inverter board...
replace the video/keyboard as well...
Feb 08, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Flickering screen
Yes, right click on the desktop, go to properties > settings > advanced,
Go to the monitor tab and try changing the refresh rate to something a little higher IE if it is set at 60, try 70.
Jul 18, 2008 | Philips 170P 17" LCD Monitor
I cant change my screen resolution correctly the screen is too big i tried installing drivers for my video and it wont let me install i found a screen that gave my options but when it changes it how i...
Hi Dubz,
It sounds to me that you might be setting the resolution to something that your monitor cannot handle. Check your monitor manual for the supported resolutions and try one of them.
If you dont have the manual try 800 x 600 or 1024 x 768 as most monitor support those resolutions.
Regards
Andy
Jun 26, 2008 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
