Question about GE Load Center Generator Interlock Kit THQLLX1
I have a GE PowerMark Gold Load Center Cat No. TM3210 with an 100A Main C/B and want to use the GE interlock type THQLLX1. However the literature says the THQLLX1 is suitable for a main breaker of 150 to 200A. Can this interlock be used with an 100A main breaker and if not, is there another model interlock that will?
The above Interlock kits are vastly overpriced. As long as the upper right hand breaker is available to use as your generator link, the kit should be good to go. Save the extra $100.
Posted on Nov 19, 2011
  • 760 Answers
Where can i get a generator interlock kit
Google is your friend in such cases. :>)
Generator InterLock Kit Manual Transfer Switch
www.interlockkit.com/ Provides generator interlock kits for connecting portable generators to home single phase panels.InterLock kit selection - ‎Introduction - ‎Catalog - ‎Accessories
Generator InterLock Kit: Choose the Right Kit for Your ...
www.interlockkit.com/interlockselect2.html Need help selecting the right interlock for your home electrical panel? Use the guide on this page to match your panel to the right kit or give us a call today.
Panel Interlock Kit Kits - for safely connecting generator ...
www.nooutage.com/interlock_kits.htm Jun 6, 2014 - Our breaker panel load center Interlock kit allows you to connect your portable generator to your electrical system safely without danger of ...
GE PowerMark Gold Load Center/Generator Interlock Kit ...
www.homedepot.com/p/GE...Generator-Interlock-Kit.../100674082 Rating: 4.3 - ‎43 reviews - ‎US$43.65 - ‎In stock There's no need for a separate generator panel with the GE PowerMark Gold Load Center/Generator Interlock Kit. This kit includes everything required to change a 150 - 225 Amp load center to a generator panel. ... Convert an existing load center into a generator panel.
Jan 31, 2016 | Televison & Video
Reading F3 and workes by it self
MAKE THIS TEST AND FIX IT. God bless you
  1. Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Nov 14, 2013 | GE Spacemaker JVM1750 Microwave Oven
I need a wire diagram for a high voltage Baldor motor CAT # 054180 79151 connect to 440VAC it's a 40HP, RPM 3525 , 3PH and it's SPEC# 40F97Z22 please help
Normal wiring for this type of 9 lead motor to 440VAC is
Connect #4 to #7 Connect #5 to #8 Connect #6 to #9
Connect supply phase A to #1 Connect supply phase B to #2 Connect supply phase C to #3
Can you confirm the CAT and SPEC numbers? They do not show up on the Baldor site. If they are correct as listed, you need to call the Baldor help line and find out if this is a special motor.
Aug 05, 2010 | Gb Electrical 100 Amp GE Load Center
Gear shift of f-150 is locked in park. The truck
Is the CHMSL ( Center High Mount Stop Lamp ) working ?
Is it a regular bulb, or did it get changed to a LED ?
If it is a functioning factory type bulb, the shift interlock solenoid is the cause.
Until you can fix the CHMSL or the shift interlock, you can turn the key to the run position ( do not start ), press and hold the brake pedal, shift into neutral, and then start the truck.
Your MY the shift interlock circuit and the brake lamp circuit are the same.
Usually the shift interlock stops working when the brake lamp fuse is blown, or if the bulbs are out ( truck does not see a load on the circuit ).
If LED tail lamps were installed without load resistors, the shift interlock circuit will not work ( looks like a burnt out brake lamp bulb )
Jan 11, 2010 | 1997 Ford F150 Regular Cab
Power cord for GE hand held mixer
I have a gold mixer also, My wife loves it. The cord went
and was unfixable. I found one on this website abtecparts.com.
The cord was $5.99 plus shipping. Good Luck
Pat
Mar 18, 2009 | Food Mixers
Trying to install a 30 amp breaker into a ge powermark gold 200
Hello, First, you need to determine if you are installing a 220 or 110 vac circuit breaker. The 220 is a "double pole" and will have (on the underside) 2 tabs for each 110 phase on your breaker box. It will also usually have a double switch tied together. A single or 110 breaker will just mount to one of the "hot bars" on the breaker box. Again, look at the underside of the breaker. Just remember you need 2 wires (usually a black and a red) for 220 and only one wire (usually black) for a 110 single. The neutral shouls tie to the neutral bar on the box (where all the white wires are connectoed to)
Of course, use extreme caution and insulating gloves when working on a circuit breaker.
Hope this helps and good luck with it. Gary
Mar 12, 2009 | Electrical Supplies
Washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Jul 23, 2008 | GE WDSR2080D Top Load Washer
GE Load Center Generator Interlock Kit THQLLX1 Logo
1,409 people viewed this question
Top GE Electrical Supplies Experts
steve morris
steve morris
ray gallant
rdjagger
Are you a GE Electrical Supply Expert? Answer questions, earn points and help others
