Question about Zyxel ZyAIR B-1000 802.11b
Hello my problem is to conect acsess pointer zyair B1000 V2
My car toyota srs porablm
air bags
get the bags scanned,
read the FSM on bags yet< (factory service manual)
or at alldata.com, DIY.
in what country? , did you read the TSB recall yet>?????
huge recall.
where is this 31 code? at>?
Trouble Code: B1000/31 (1.8L L4 VIN R Auto)
Airbag ECU Malfunction * Airbag sensor assy center
remove battery neg lug before touching any SRS parts.
B1000/31; Center Airbag Sensor Assembly Malfunction (2006 Corolla From 07/2005) DESCRIPTION The center airbag sensor assembly consists of a deceleration sensor, safing sensor, drive circuit, diagnosis circuit, ignition control, etc.
If the center airbag sensor assembly receives signals from the deceleration sensor, it determines whether or not the SRS should be activated.
DTC B1000/31 is recorded when a malfunction is detected in the center airbag sensor assembly.
If only DTC B1000/31 is output, do not clear the DTCs, replace the center airbag sensor assembly.
If any DTCs other than DTC B1000/31 are also output, troubleshoot those DTCs first.
use a real scan tool
and see all errors.
if not you guess wrong.
Feb 02, 2015 | 2006 Toyota Corolla
B1000 airbag code
buick regal forum find with google
Feb 07, 2013 | 2000 Buick Regal
I get a http error 404 if i try to acsess gmail by address or icon on explorer8 . I am using a cell modem to conect to internet can surf te net and download only gmail even hotmail works on my computer
for the http error 404 you can use another search engin instead of explorer8, as Mozilla Firefox.this problem create when the signal strength is slow or the connectivity of the network is poor.
Apr 08, 2010 | Google Gmail
OBDCs: P1134 P0711 P2300 B1000 Hyundai Santa Fe 2002
P1134 - Oxygen Sensor Circuit Malfunction (No Activity) P2300 - no such code, B1000 - no such code, P0711 - Transaxle Fluid Temperature Sensor Rationality Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Sep 30, 2009 | 2002 Hyundai Santa Fe
I have a Zyxel P-660HW-T1 V2 and cannot conect to
hello i had the same problem after i reconfigured mine i could not gain internet access but as it turns out i hadnt payed my bill so it wouldnt allow me access with the same router as you
p.s my isp was digiweb
Hope this helped
Shane
Jun 15, 2009 | Zyxel Prestige 660HW Wireless Router...
WEP key for ZyAir B-2000
go to the web page of the router default ip address is 192.168.1.1 and user name is admin and password is 1234. after then go to the wireless option in that seciurty option is there in that u get the wep in that you can get the password you change it that's all
May 05, 2009 | Zyxel ZyAIR B-2000 Wireless Router
Internet
first go 2 settings. go 2 internet enter it go to connection settings. click connection 1 2 or 3. click search 4 an action point and chose any gold lock acsess point. it will show the strength( 3 bars strong conection 2 bars fair conection 1 bar weak conection 0 bars no connection.)
Apr 11, 2009 | Nintendo DSi Black Console
Conect eq. with the turntable
hi there, first you have to pit your turntable phono at the pre - amp phono to amplified then after you can put now direct into your equalizer and then to your amplifier
Dec 30, 2008 | Spectrum Technical Hifi EQ-B5200...
Configure new Zyair router
Hi Dflori,
Try this site,
http://portforward.com/routers.htm
Scroll down to your Zyair, it lists several, click on it, and pick program you wan to work with. Good luck!
Jan 06, 2008 | Computers & Internet
Zyxel ZyAIR B-1000 802.11b Logo
65 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
