Question about Microwave Ovens
Running hot. The ice is wettish and melty and the countertop above unit is warm to the touch
  • sregester35 Sep 03, 2010
    This is a freestanding ICE MAKER not a microwave!!! Whirlpool GI1500phB6
  • 2,272 Answers
Please give the exact brand and model number.And if its microwave oven,then please give some more detail about the "ice is wettish" in oven. Keep updated.Thanks.
Posted on Sep 03, 2010
My microwave sparks while running
better quit using it till you have a service man check it out .
Mar 04, 2015 | Kenmore 1.6 cu. ft. Countertop Microwave...
My freezer is icing up and water is dripping from the ice. I'm having problems closing the door as a result, and removing frozen food.
Try this, If it is an upright fridge, remove the flont lower vent grill. Ten to one the coils are covered with dust and cobwebs. Not implying anything, mine was horrible. Vacuum all the stuff that has accumulated untill the coil is nice and clean.. Unplug the unit so you don't get into the moving fan blades and don't reach into the space, There are hot componants. Good Luck, Ned
Aug 23, 2009 | Microwave Ovens
Replaced the fuse and it immediately blows. My wife cooked several large potatoes got it ral hot before failure
see the steps and eliminate short circuit use the common sense: God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
However if after replace the fuse the problem remain, you must test: a) power cord for short b) outlet wall for ground improperly c) HV transformer faulty d) Rectifier HV faulty e) Magnetron faulty. d) power supply faulty replace or repair filter diode, resistor. etc Or call some experimented service tech for troubleshooting.
Jul 27, 2012 | Sharp R-820B Convection/Microwave Oven
Started icing in freezer compartment so i defosted 4 24hrs. switched back on now freezer not working at all in fact its getting warm in freezer compartment fridge seems ok compressor seems 2 get quite hot...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 25, 2011 | Microwave Ovens
Double door fridge freezer not cooling down heating the panel between the doors
Hi and welcome to FixYa, I am Kelly
The symptom you describes it that of a condenser fan not running. Open the fiberboard panel in the back of the unit and check for substantial lint build up on the condenser coils and fan. Clean it thoroughly. If the compressor is running the condenser fan is supposed to be running. You can push gently the fan blades to see if it is trying to turn....
Once your done cleaning... if you can not get the fan going.. use an external fan directed at the rear bottom of the refrigerator until you can get a new fan. All the external fan is doing is removing the heat... that the fail fan can not.
The noted hot area between the doors should just be warm to the touch once the condenser coils are bing cooled properly.
Thanks for choosing FixYa,
Kelly
Apr 28, 2011 | Microwave Ovens
I am getting power and the freezer appears to be working but the fridge is not cold at all, any suggestions? Many thanks Dave McRae
Hi Dave and welcome to FixYa, I am Kelly,
Take a look in the back of the freezer compartment. Look for any signs of icing on the back access cover. Usually but not always the evaporator coils freeze up because the unit is not automatically defrosting properly or there is a problem with the evaporator fan not running fast enough / at all. Press gently with your hand of the back cover of the freezer compartment and feel for ice. Also check the front of the chassis for signs of being HOT. It is ok to be warm not hot.
Also check to see that the light goes on and off as you actuate the light switch plunger. Some units have the door switch in the top of the door hinge but most have the switch in the door fold area of the chassis some where.
If you find that the evaporator coils have iced up:
  • Perform a manual defrost of the unit but first unplugging it
  • Remove the freezer contents
  • Direct an external fan into the freezer compartment for just over 2 hrs. (makes a water mess)
  • After 2 hrs clean up the water mess and return the unit to normal service.
  • Watch after 3 days if the fresh food compartment once again starts warming up. If it does you have and automatic defrosting problem.
No ice noted:
  • Possible temp control problem (Thermostat / cold control or thermistor)
  • Possible Air Damper problem. There are 2 kinds of air dampers. One is electrically controlled and the other is nothing but a mechanical baffle that is positioned partially open. If you have the electrical type the air damper motor may have failed or the movable baffle is stuck.
Front of chassis is almost HOT to the touch vs warm:
  • Open the back of the unit by removing the black fiberboard cover and inspect for lint and that the condenser fan is running anytime the compressor is running.
Light always on:
  • Door switch failure. Some door switches also control the evaporator fan along with water in door and ice in door functions. The water and ice in door should NOT work with the door open.
The above is pretty much an in home repair techicians check list for the symptom you describe.
If you discover that you have an automatic defrosting problem I will need you MAKE & MODEL number via your next response here so I can tell you what you can do to troubleshoot. (
Kelly
Feb 28, 2011 | Microwave Ovens
Microwave making loud noise while heating food. And food does not get warm or hot.
sounds like the magnetron has failed on this unit...it is located in side behind the control panel touch pad and if replaced usually requires disassembly of the outer shell of microwave... it is a common problem with microwaves and can be fixed just requires taking apart unit to do it...good luck to you
Jan 09, 2011 | Kenmore Microwave Ovens
WATER IS RUNNING OUT OF THE LID OF FREEZER WHEN OPENED. OUTSIDE OF FREEZER IS VERY HOT TO TOUCH. HOLIDAY MODEL LCH0501PW
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 28, 2010 | Microwave Ovens
Our GE countertop microwave key pad does not work. The start and clear button does not work. owners mamual jes1651 . unit is 2 years old.
HI. Kindly, unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the error continues, the touch pad should be replaced asap.
Oct 19, 2009 | GE Microwave Ovens
Microwave Ovens Logo
18 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
