Question about Sharp AL-1655CS Laser Printer
How should I change the cartridges - Sharp AL-1655CS Laser Printer
  • 1,110 Answers
What cartridges do you need to change? There are only 2 in this machine. If you open the right side door with the release button then open the front door you can see the 2 cartridges. The one on the left side with the green button on it is the toner/developer cartridge. It is replaced most often. When it needs to be replaced you will see a light on the operation panel that looks like a stack of 6 dots. You just press the green button down and slide the cartridge out.
Just to the right of the toner is the drum cartridge. When it is due for replacement you wil see a light on the panel that looks something like a small flashlight battery or barrel. You can just slide the drum cartridge out, but only after removing the toner cartridge first. The toner cartridge must be out of the machine before removing or installing the drum cartridge.
Good Luck and Thanbk You using Fixya.
Posted on Sep 03, 2010
How to change the ink of printer Epson stylus Office BX300F. Show me in the computer to change the ink in printer now.
Turn on your printer and raise the lid or press the cartridge changing button. Wait for the cartridge carrier to slide out.
Lift the cartridge holder lid, and the cartridge will pop up for removal.
Carefully remove the tape from the ink opening on the bottom of new cartridge.
Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
Close the cartridge holder lid and press the cleaning button to charge the cartridge.
Close printer cover.
Watch here full details:-https://www.youtube.com/watch?v=8gL5xoiDenA
Still unable to change the ink, you should go to customer support at +1-800-243-0051 ' +1-800-243-0019
May 05, 2017 | Epson Office Equipment & Supplies
What is the cause of my printer o be saying change cartrige when i already change it
It may be some reasons:
1. Cartridge incorrectly changed. Just be sure to remove and set the new cartridge correctly.
2. No good connection. Sometimes ink spills on the cartridge connectors OR the protective plastic still set on the cartridge. Clean the connectors with a soft cloth and be sure to remove the plastics - see installation guide on cartridge.
3. No procedure was done. To change a cartridge correctly, some printers require a procedure for it, be sure to read the user manual how to change cartridge.
Other non-common issues: bad new cartridge, faulty printer, software or firmware glitch, etc,
Apr 15, 2010 | Brother MFC 420CN All-In-One InkJet...
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Cannot use ink cartridge after initialization. Happens every time I change cartridges although cartridge was sent to me by HP themselves. When do I change the cartridge - I presume before I turn the...
You change the cartridge whenever the printer software says to, or when the color starts to fade on prints. You can change the cartridge with the computer and/or printer on or off, it doesnt matter
Sep 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
NX400 printer - cartridge not positioned to change cartridge
The problem occurs when trying to change a low ink cartridge before you are prompted to do so. In that event, you must go to setup, maintenace, change cartridge and it will move the cartridge into position.Do not try to force the cartridge into position.
Jun 22, 2009 | Epson Stylus C86 InkJet Printer
Changing ink cartridge
Mar 07, 2009 | Epson Stylus C86 InkJet Printer
HP 1610, Remove Cartridge message
also replace the colour cartridge as it is not showing but the printer is not able to detect that cartridge also.many a times it solves the problem.
Sep 30, 2008 | HP PSC 1610v All-in-One Printer
Sharp AL-1655CS Laser Printer Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
