Question about Symbol LS 4071 Handheld
I need to get the bar codes that I can scan to tell my LS4071 scanner to add a 'tab' or 'carriage return' character as a suffix to the scanned data. Where can I find those bar codes? thanks, Ken
SOURCE: I need three characters in suffix on LS2208
so you need it to be 0AH + 03H + 03H/BARCODE/PRESS ENTER definetly try adf rules
Posted on Dec 23, 2008
SOURCE: I have an LS4071 with an RL474 base. The cable
When I connected this scanner (purchased at a great discount through eBay) to my computer using the keyboard wedge (with a ps2 connection - the round connector) I received the error message that my computer could not recognize this external hardware. I went to barcodediscount.com and ordered the usb connector for this scanner as usb connections are usually recognized. The part # for this connector is STI85-0200R. It cost 72.55 with shipping, but I received the scanner at such a wonderful price that I thought I'd chance it and try it with a usb rather than a keyboard wedge connector.
The computer immediately recognized the usb connection, and the usb connector comes with a manual with codes to enable proper scanning, but still no luck getting the data into the computer. So I called Symbol's technical support department. The technician told me to remove the rubber "boot" at the bottom of the hand held scanner (not the scanner base) by pulling on the front of it (where the 2 little round circles are). It's tough to remove, but keep at it. Then gently remove the battery and unplug it, then plug it back in and reattach the base. He said this would reset the battery. Voila!!!! Sucess!!!!
If your scanner's keyboard wedge connection is recognized (a little popup window will say that it is a Symbol barcode scanner and that it is installed and ready to use), try taking the battery out and putting it back in to reset it. Hopefully this will also work for you. Symbol's technical support # is (800) 722-6234.
Posted on Mar 23, 2009
tommya300
  • 724 Answers
SOURCE: Symbol Scanner LS4071-I1us
transltor and data comparison failed?
Posted on Jul 27, 2009
SOURCE: I have a brand new MC3090G-LM48H00LER wireless bar
find WLANs showing adapter unavailable
Posted on Sep 18, 2010
Joshi_Z
  • 567 Answers
SOURCE: i want to program my
In order to program the device please refer to the "Programming Reference" on the guide available on this link.
There are sample codes you can scan to set up the device as per your requirements listed above.
If this doesn't work for you, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Posted on Nov 04, 2010
How to program a bar code scanner to have 3 "TAB" in prefix
In the appropriate manual (see link)
https://portal.motorolasolutions.com/Support/US-EN/Mobile+Networks+RFID+and+BarCode+Scanners/Bar+Code+Scanning/General+Purpose+Scanners/LS2208_US-EN
Go to the proper symbology page scan the prefix start then find the tab character and scan it three times to add the prefix then scan the complete barcode for the prefix
May 16, 2016 | Zebra LS2208-SR20007R-UR
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
What would I put under the suffix and prefix when bar coding? My scanner is Symbole LS 2208
Hello Norma, you can use the suffix or prefix to send characters, which are not included in the barcodes tgehter with the scanned barcode data.
If you dont need any character before or after the data, you can leave it blank.
It is usually used to add an Enter or Tab to switch to the next line, while scanning to some application like excel.
Nov 02, 2010 | Symbol LS2208 Handheld
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
Manual carriage return necessary after scanning barcode
With the Symbol scanners, they usually come with a sheet at least of scan codes to configure the scanner. One of those bar codes will have the option of not needing to manually hit the carriage return. What model scanners are they? You can probably find the codes from Symbol.
Sep 17, 2009 | Symbol LS 2208 Barcode Scanner
I need to program a <tab>suffix character
Just go to page 8-6 and scan the "Enable Tab Suffix" Barcode that is 5th down from the top of the page. It took me awhile to figure it out too. Hope this helps someone since the question is a year old...
Jul 09, 2009 | Metrologic Instruments MS9535 VoyagerBT...
Scanning way
I found the solution:
The scanner by default send data without suffix or prefix. If anyone wants to have CRLF after the scanned data, he must set the scanner to send sufix after the data.
Read the page 5-78 in the manual :)
Oct 30, 2007 | Symbol LS 4071 Handheld
Symbol LS 4071 Handheld Logo
51 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
