Blowing air, but not cooling...which fix is my cheapest option?
  • 24 Answers
If compressor is running check freon
Posted on Sep 03, 2010
How do I fix my A/C
can be a bad fan motor, defective capacitor or contactor issue. capacitor is cheapest fix if bad.
May 11, 2014 | Bryant Heating & Cooling
Heater blows cold air
Check the coolant level, low coolant can cause this. The other thing is the heater controls. Generally not the dash but the controls behind the dash that blend the hot and cold. The blend door might be stuck, broken or loose. You can usually see the controls under the dash behind the glove box
Feb 15, 2014 | 2000 Dodge Durango
I have a 2000 Dodge Durango. The heater blows cold air, the a/c works fine. I was told this could be a bad fuse.
the thermostat that regulates the water temperature is bad. it is in the open position keeping the water from heating
Oct 01, 2013 | 2000 Dodge Durango
2004 chevy aveo ac / heat not blowing
Blower motor under the passenger side dash maybe the problem ! Testing electrical circuit would need to be done to see if that is the problem .
Blower Motor Problems Auto Repair Help
Please give me the cheapest possible fixes first. Sorry , but it doesn't work like that . Testing to find the problem an then replace the part or fix the wiring etc. Your best bet , take it to a qualified repair shop .
Sep 07, 2017 | 2004 Chevrolet Aveo LS
My air conditioner blows hot air and my heater blows cold air. The heater will warm up after the engine has been running for awhile but when I turn the air conditioner on it takes power away from the...
check your blower motor under the passenger side of the dash, round plastic box three screws pull it out something might have fallen though your cowl and chewed up the fan blades. as for the ac your r-12 is probly empty or has a leak bring it to a local garage and have them flush and fill your cooling system. heater would be your thermostat not openig properly, by far your cheapest fix under ten dollar part.
Apr 04, 2012 | 2000 Toyota 4Runner
New ac does not cool
mcdevito75 here, The cheapest way is with the warrantee card you mailed away went the unit was new. If no warrantee, then check out the A/C repair shops in your area, Sorry.
Jun 23, 2010 | Goldstar KG6000R Window Air Conditioner
Heater won't blow warm air
You need to have your cooling system looked at. Either your heater switch (in dash) is broken, your heater hoses are disconnected, or you are low on coolant/water. It could also be your blower motor but as your question is phrased I'm assuming it is blowing, just not warm air.
Jan 05, 2010 | 2003 Toyota Corolla
The HVAC registers in the car will not blow consistently, in a 2001 Ford Taurus. What are the possible problems? Sometimes the air will blow, sometimes it won't. Sometimes after the car is on for a...
Check pressure of air con fluid. Sounds like it needs refilling.
Most good car centres sell the gas in a can - with a pressure gauge.
Try this first as it's the cheapest option to start.
Aug 04, 2009 | 2001 Ford Taurus
Heater Troubles
possibly/most likely, a restriction of some type to core or in core, more than likely corrosion internally. Cheapest & best thing to try is complete cooling system flush, & reverse flush, to move that out of there if it will come. If that fails, I would circulate C.L.R. through heater core to help remove any calcium etc deposits.
Dec 12, 2008 | 2004 Nissan Altima
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
