Question about Medion MD-40954 Notebook
Medion MD41349 How do you remove the covers to upgrade RAM? Thanks Mike
  • wrq77 Jul 17, 2008
    I have unscrewed all the screws on the underneath but can't seem to slide the keyboard off. Is there something I am missing?
    Problem Solver:
  • 7 Answers
You need to remove all the screws from the back also, then remove the cover to the rear on the bottom and remove the wireless card (make note as to connection colours) and there is 2 (I think) screws under there, then one also under the battery, then the whole top opens up.
Make sure you have removed all screws from the bottom case, including the four under the rubber feet at the rear.
This was the most awful laptop I have ever worked on!
Posted on Oct 10, 2008
    Problem Solver:
  • 8 Answers
Medion note book wim 2160/md96290 have since an update in vista problems with my usb ports, does not recognise hard ware i plug in any more cant find hardware whats plugged in inc wifi dongle/mobile internet,"cant find the modem" any suggestions how to get my usb ports back to normal answers to hhallers@gmail.com
Posted on Jan 03, 2009
I have also tried this and it won`t slide forward
Feels like its got a screw underneath the keyboard holding it up?
Posted on Sep 21, 2008
You have to take the laptop apart by removing all the screws from the base of the laptop, turn it over open the screen, the whole of the keyboard top including the touch pad slides forward, then take off the cpu fan, and put in your upgrade ram, assembly reverse of disassembly, good luck
Posted on May 25, 2008
How do you open the back of my Medion MD41349 notebook
Turn it over and start unscrewing screws. But you'll also have to remove the lcd screen, keyboard, palmrest and motherboard to actually get the whole back off.
Mar 22, 2012 | Computers & Internet
I'm currently trying to repair a Medion cybermaxx MD41349, But the laptop doesn't turn on (boot/reboot) 100% of the time. only rarely it will turn on as normal. How do i cure this? without paying? It's...
have u checked your power supply and the plug in port if loose needs sodering somtimes its the power pack shorting out if its the board ebay has replacements for around 40-50 dollars..
Apr 10, 2011 | Computers & Internet
How can I upgrade ram?
check for the clock speed of your old ram.... check for the type(DDR/DDR2/DDR3).. check your motherboard for capability to adapt greater capacity of new RAM.... buy a new one with same specifications but of greater capacity.... replace it with the old one or you can plug it to the empty slot if found any on the board....
Apr 20, 2010 | Medion M3 Composer 5200 PC Desktop
How to Upgrade to max RAM
The Acer Aspire One can be upgraded to a total RAM of 2Gigs. This will allow for you to upgrade to Windows XP Pro and also to Microsoft Office 2003 as there is no version of Office Professional. If you would like more specifics on your particular model, please look here. http://www.laptopmag.com/review/laptops/acer-aspire-one-10-inch.aspx?page=3
Upgrading RAM is a fairly simple process. As this is a fairly compact laptop in design, you will have to upgrade to a new 2Gig RAM module and basically discard (or sell) the one you end up removing. In order to find out the type of RAM you'll need, remove the cover as show in the picture and the info for the existing RAM should be written on it.
Apr 19, 2009 | Computers & Internet
Medion ram upgrade
I'm not a guru, but your predicament is pretty simple.
Depending on your OS (XP 32 bit, XP 64 bit, Vista), the OS will be able to recognize a certain amount of RAM. XP 64 Bit will be able to recognize up to 6GB of RAM. Vista, I have no Idea. 32 Bit, what you're seeing right now.
Sorry for wasting a bit of money on that last stick.
Nov 30, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Need to know what type of RAM my MD 1921 has so I can upgrade.
Hi KF27,
Your system has and supports PC SODIMM DDR RAM with a MAX support of 1GB. You currently have 512MB of RAM (2x 256MB), so your only option is 2x 512MB of RAM..
I hope this helps you out!
Sep 03, 2008 | Medion Computers & Internet
I WANT TO REPLACE MY RAM MEMORY TO UPGRADE TO 2GB
Hai,remove ram and replace the sam ram (ex,DDR,SD-RAM).start the processor .
Jul 05, 2008 | Medion Computers & Internet
Memory upgrade
The memory should be DDR II Ram. To find how much ram you have simply click on Start then right click on "My Computer" and click properties. Chances are you have 512 ram. It will tell you in the lower right hand side along with your processer and windows version. Once you have found out how much ram you have, turn off your computer flip it upside down and pull out the battery. Then you should see a cover with one or two screws in it that measures about 3 inch by 4 inch. Remove the screws and take the cover off. This is where your memory goes. If there is 512 memory in your computer you will either have 1 512 memory stick or 2 256 sitcks. Remember that any time you upgrade memory it is best to take out the old memory and replace with either one stick of higher ram or two of equal ram. Never mis a 512 and a 256 or 512 and 1gig ect. Take the ram stick/sticks out and bring them down to the store with you just so as to get the correct memory. Also, remember when you replace the memory, if you are just upgrading to one 1gig stick to put it in the A DIMM slot. This is the primary ram slot.
Apr 29, 2008 | HP Pavilion dv6000z Notebook
Medion md95278 upgrade
http://www1.medion.de/downloads/templates/hilfe_us.html
Need that number before i can find the correct manual for your machine.
In any case, the ram should be accessible via a small panel on the bottom.
Oct 14, 2007 | Medion MD-40954 Notebook
Medion MD-40954 Notebook Logo
1,118 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Martin Murray
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
