Question about Frigidaire ATF6000ES Front Load Washer
On starting washer, terrible rat-tat-tat nose, door lock not engaging....
Washer was working fine, then when going to re-start a load, start was pressed, but only the noise happened. no warning code, no door lock engaged.
i pressed cancel, as it seems that nothing was going to happen, door remained unlocked.
by feel, the vibration of the noise was coming from the bottom panel-
HELP?!
  • jakema May 11, 2008
    turns completely fine and quiet-
    started in the middle of a cycle apparently- belt seems likely, yes?
    Genius:
  • 1,665 Answers
Try to turn can by hand and see if any noise produced by central bearing
Posted on May 11, 2008
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Crosley washer CFW7500KRO - Door lock won't stay engaged
Unfortunately I had the same problem and it ended up being the control board not sensing the switch being closed. Had to replace the control board
Sep 06, 2012 | Washing Machines
All cycles are working except the spin cycle. I have visually inspected the wiring connections and motor and dont see any obvious issues. There are no error codes and the LED lights seem to be functioning...
Because of the high spin speeds of front load washers, the doors are equipped with a latch and lock mechanism to prevent the door from being opened during the washers operation. These locks will often be actuated by a solenoid or wax motor to ensure they remain latched during the wash cycle. This model uses a two stage lock that latches the door when the load starts, and then when it is time to spin, the second lock engages to ensure the door is properly secured prior to beginning the spin. When this second lock engages, it also closes a set of switch contacts (the auxiliary door switch) telling the control board the door is closed and locked. If for some reason this switch is not closed, the washer will tumble during what would normally be the spin cycle until the entire cycle is complete.
Jul 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
May 31, 2011 | Frigidaire FTF530FS Front Load Washer
The door lock on my frigidaire washer
The locking mec is jambed or broke easy fix hope this helps
Apr 29, 2010 | Frigidaire GLTF1670A Front Load Washer
110cc pit bike; The kick start kicker used to
Hello - i don't know whether you have sorted this or not, but ill help you anyway. Well.. First of all to get to the kickstart mechanism, you need to drain the oil. Get an oil tub, or a metal jug, or anything along those lines and place it underneath the engine..
Underneath the engine there is a big bolt which should have a red rubber washer, well.. undo that. The oil will drain out of it, tilt the bike left and right to make sure it's all out.
Now you undo the bolts, holding the clutch cover on, this will reveal the clutch. In the middle of the clutch there is a ring with teeth on it, bend them out and the clutch will just pull off, also there is a circlip so be careful and dont lose it. Now it's time to take the whole engine casing off, just undo all of the bolts, and keep them in order because some are different sizes. There is a large gasket so make sure you dont rip it!
There it is. The spring mechanism, if you want to go further, you will have to take the cylinder off to split the engine to get to the gear box.
Jan 14, 2010 | Pit SSR 110CC Pro Beginner Bike
Door not locking
Doot lock hook may not be engaging or door lock is faulty- wiggle the door around while pushing on it, check the door hook , replace the electric latch
Sep 12, 2009 | Samsung WF337AA Front Load Washer
The door lock isn't engaging.
you may have bent thr hing on the door if you lean on them on top they will bend try a little lift on the door then close
Sep 11, 2009 | GE WSXH208A Front Load Washer
Front loader not starting
First check if u can close the door with no or less clothes and see if the lock is engaged.. else if u find the door not locking see if there is any garments or threads blocking it.
Thankyou
Jun 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
83 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
