Question about NEC Computers & Internet
NEC Opticlear MultiSync LCD1070 GX Monitor Video Input 2 D-SUB out of range comes up frequently, then the screen goes dark, and my AMD 64 Fry's Computer 64 AthlonX2 reset button must be pushed in. Sometimes, I can actually access the web site, then Resolution Notifier Op Res is 1280X1024 box comes up with See users manual for more information. Then the screen goes blank, and a reset button must be punched on the PC terminal.
antiochpc
  • 1314 Answers
SOURCE: NEC 1940 CX Monitor
Here's the user's manual: http://www.necdisplay.com/cms/documents/UserManuals/17401940CX_053106.pdf Basically, according to the manual, you have to go into your menu and turn off the resolution notifier.
Posted on Jun 15, 2007
tantong
  • 138 Answers
SOURCE: computer screen goes blank
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After the scree goes dark, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 28, 2008
judesoul
  • 127 Answers
SOURCE: out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
Posted on Feb 06, 2009
  • 120 Answers
SOURCE: The resolution notifier keeps popping up (NEC
It probably is warning you that your video graphics adapator is puting out a non-native resolution to the monitor.
LCD monitors are designed for a specific resolution. If you don't use that resolution, the LCD has to try to mimick the resolution you've asked for.
Check your display settings and also consider updating your graphic driver if a new version is available.
Posted on Oct 13, 2009
  • 95 Answers
SOURCE: Video input: 2 D-sub No signal /Video input 1 DVI-D No signal
Below is a link that may help you...Good luck http://www.techspot.com/vb/all/windows/t-35070-DVI-to-DVI--No-Signal-on-LCD.html
Posted on Apr 06, 2010
Hi, NEC P221 W multisync has increasinly been displaying fine vertical cyan and magenta lines, most evident on white areas and grey areas respectively.
Your monitor is no longer in production but there might be some support for it. Go here to see what's available: Product Support You might need to upgrade.
Jul 28, 2017 | NEC MultiSync FE950 (White) 19" CRT...
DISPLAYING ON SCREEN THAT VIDEO INPUT OUT OF RANGE
Right click on the back ground of the computer desktop. If windows XP click properties, if vista click personalise. Now look for settings and move the resolution slider to 1024 X 768. This is the native resolution for this monitor.
If you still have the HZ error, click on advance look for the monitor tab, and make sure it is set to 60Hz
Mar 02, 2012 | NEC MultiSync LCD1525V (White) 15.1" LCD...
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Nec Multisync LCD 195VXM+ black screen after turning on computer
I'm thinking your video card is sending a signal the monitor doesn't recognize.
You'll need to start the computer and hit F8 until you get the black and white menu. Choose the VGA mode and it should work well enough for you to adjust the refresh rate or the resolution to get the monitor to work
Aug 28, 2009 | Computers & Internet
NEC 17'' Multisync CRT monitor does nothing when turned on
the green is working ok but orange is usually waiting for an input from the pc (no input signal)
Mar 08, 2009 | Computers & Internet
Nec 17'' multisync lcd monitor not working properly
What is the problem? Did you try plugging it into another working computer?
Mar 03, 2017 | NEC AccuSync LCD71VM 17" LCD Monitor
Monitor not coming on at all
i think the memory or the graphics card of your system unit have loose contact try to remove it from the slot and
insert it back again.im sure 100% it gonna work.
Mar 11, 2008 | NEC MultiSync 1770NX 17" LCD Monitor
Computers & Internet Logo
257 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
