Question about Cycling
I own a gym and several of my Tomahawks have pedals that have fallen off. It appears that the threads have been completely stripped. Also, How do I adjust the tension knob so that it operates the way it should?
  • 11,800 Answers
The threads on the pedals are a problem  - you could wrap the bolts in aluminium foil and screw them by force, the foil taking the slack, but, for safety, you should use some metal epoxy adhesive and glue them in place
If by tension knob you are referring to the brake adjust then the adjustment is to be done by the customer, the way it likes. If by that you refer to the belt tension adjustment then it should be tighten enough that when you press on the middle of the belt it flexes just under half an inch.
Posted on Sep 03, 2010
Model :x 3519 right pedal stripped
If it is the pedal's threads that are stripped just purchase a new pair. If it is the threads on the crank that the pedal goes into then either replace the crank arm if it's the left side or find a bike shop that can install a "Helicoil" to repair the crank. Threads will be stronger than the original
Jul 31, 2017 | Cycling
There are no threads on the crank arm to screw a pedal on. What do you do now?
1. replace the crank.
2. Purchase a Heli-Coil or other brand at an auto store. It looks like a tube with threads on both sides that will screw in to the stripped hole and there by install new threads. Bring the pedal to the auto store to make sure it will thread in to the "female" threads on the Heli-coil.
The problem is the pedal is steel and the crank arm is soft aluminum. Also, people damage them because one pedal is normal thread and the other is reverse thread meaning you turn clockwise to loosen.
Jul 29, 2014 | Mongoose 26" Mens XR-75 Mountain Bike
Pedal stripped
You will need to have that crank arm replaced. They do make repair threads, but the price to install is just as much as replacing the crank arm. Your local bike shop can provide the correct parts.
Mar 28, 2014 | Schwinn Cycling
Stripped bicycle pedal
Better replace the pedal and most probably the crank arm as well. Sometimes a new pedal can cut the threads true again on the crank arm but the crank arm may need replacement too, depending on the damage. Remember to fit the correct side pedal. The pedal threads differ between left and right and pedals are usually marked "L" or "R".
Jan 04, 2014 | Huffy 26" Womens DS-7 Dual Suspension...
Huffy pedal
You need to replace the pedals( they come in pairs) but you have to make sure the crank arm isn't stripped also...if it is you'll have to replace that as well. That usually happens because the pedal wasn't tightened right in the first place
Aug 12, 2013 | Cycling
The bolt (screw) attaching the right pedal was stripped. Where can we purchase a replacement? Thank you.
If the threads in the crank are stripped it will likely need to be replaced as well as the pedal. They come in pairs. I advise you to get the bike to a real Bicycle Shop because special tools are required. BTW: the left pedal is LEFT threaded.
Aug 11, 2011 | Motobecane 400HT
The pedal assembly on my blackwater somehow got stripped always had problem with pedals coming off
If the thread on the crank arms that hold the pedals are stripped, you will need a new set of cranks. That is definitely a job for the bike shop. Make sure the pedals are snug in the arm, Right side pedal has right-hand thread, left side (looking down when you are on the bike) has a left-hand (reverse!) thread.
Jul 10, 2011 | Huffy Blackwater Men's 26-Inch Mountain...
I have a rb260 and the left pedal was threaded on crooked and now it's stripped and will not stay on.
The left pedal is a left hand thread.
if it is stripped the only fix is a new one, and possibly a new crank as well
Jan 22, 2011 | Cycling
Precor EFX 546 elliptcal shuts off
Your problem is most likely due to the magnetic sensor on the right side of the unit under the plastic housing.
The right pedal arm, has a magnet emeded in the on the inboard side of the arm. When the arm comes around and passes this sensor at the bottom of the unit, a pulse is generated and sent to the computer.
The mangetic sensor on the frame of the unit, may need to be adjusted to a closer proximity with the pedal arm magnet. Assure the arm does not strike the magnetic sensor however.
It's also possible the sensor has come loose and fallen into the base of the unit.
Mar 22, 2009 | Exercise & Fitness
Cycling Logo
20 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
