Question about RCA D61W20 61" Rear Projection Television
TV WILL NOT TURN ON
THE GREEN LIGHT COMES ON 3 TIMES
  • RCA Master
  • 8,617 Answers
Check for solder cracks around the flyback and around the line coil next to the flyback. If that doesnt help go to this link as you will most likely need a flyback they have them and offer free assistance.
http://servicemanuals.vstore.ca/
Posted on May 11, 2008
5 Suggested Answers
  • 579 Answers
SOURCE: power light
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price (less than $200) and install it in the old lamp yourself. really easy.
Posted on Jan 03, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Posted on Feb 20, 2008
Slinteriors
  • 8617 Answers
SOURCE: model d52w20b the green light comes on flashes 3
Replace the CP150, CP120 and CP114 capacitors. You can get the RCA repair Kit by that same name from www.tvrepairworld.com which also has the CD with instructions.
Posted on Jan 14, 2010
Testimonial: "if i can figure out what those are and replace them then thank you it was very helpful"
  • 3741 Answers
SOURCE: Tv green light flashes on and off 3 times. Never comes on.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
check the components as given above and if necessary replace the components to solve the issue.
This will help. Thanks .please do rate the solution positively .thank you for using fixya.
Posted on Mar 17, 2010
I can't get my tv to turn on. I turn it on and the green light comes on 3 times and the light only stays on for 3 seconds and then turns off. Can't get anything to happen with screen. Can you help me
Does it sound like it's coming on then powers down? Mine turned out to be the bulb. I bought a bulb on Ebay for less than $90.00 and installed it myself.
The bulb was inside a square metal housing, pull housing and bulb out of tv, replace the bulb reusing the existing housing, then replace..... Pretty easy fix, and I'm not all that mechanically inclined. Good luck!
Apr 05, 2013 | Televison & Video
Tv wont turn on just the green light comes on 3 times
Ur tv DM power supply board have dead leakages capacitors.U have tools,solders and soldering iron?U know how to do soldering.Tries websites like Tvrepairworld.com,Tvrepairkits.com buy a capacitors kit to replaced dead leakage capacitors to the DM power supply board.
Jul 05, 2010 | RCA P61940 61" Rear Projection Television
I turn the tv on the green light comes on three times but no pic
maybe you did the child lock which doesent allow you to turn the tv on unless u clck some buttons look in ur booklet and search for how to unblock the child lock or the 2nd try the turn on button and the ok button at the same time if it doesent work forgive me this happend to me as well
Mar 17, 2009 | Televison & Video
Tv's green light comes on then off three times
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Feb 08, 2009 | RCA Televison & Video
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Sep 07, 2008 | Emerson EWL3706 37 in. LCD Television
RCA D61W20 61" Rear Projection Television Logo
44 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
