I have a problem with my camera when I put i t on its on clock set, when I put on date etc or canel it tells me to power off and then on. But it comes back clock set. I have taken out battery and memory card. but still doesn't work. If you can help that would be much appreciated. Thanks in advance
Yes I had the same problem but read a solution that worked. All you have to do is to carefully open the camera. There are 2 cables, one that leads to the rotating knob that gives you video, low light settings, etc, and the other below that which serves as the timer, flash etc. disconnect both of them and put them back in. power on the camera, it should work now. now put the camera back together. winner.
I have a brand new Sharper Image® Mini Portable Camcorder after 1st charge it won't...
(More)
I have a brand new Sharper Image® Mini Portable Camcorder after 1st charge it won't turn on anyone have the same problem?
Dimage A1, initially no image viewable on screen or through viewfinder on record or movie mode but...
(More)
Dimage A1, initially no image viewable on screen or through viewfinder on record or movie mode but OK on playback. Now there is nothing on screen but the menu & playback viewable through the viewfinder but then not switching to screen as it normally would?
After setting up the language and date, when exiting the menu - display shows nothing. Also the lens...
(More)
After setting up the language and date, when exiting the menu - display shows nothing. Also the lens stands open? Any idea?
