Question about Brother HL4040CN Laser Printer
Our Brother HL 4040 CN printer has this message "Drum Error, slide green tab on durm unit in each color." We cannot find our Users Handbook - and this in one printer networked to 4 other computers. Can you provide documentation to help us solve this problem?
Since changing the drum for brother hl 40-40CN , the printer won't work.
Posted on Oct 19, 2010
Drum error. slide green tab in each color - Brother HL4040CN Laser Printer
Try removing all the toner carts and remove the drum unit from the printer. Using the upholstery tool on your home vacuum cleaner, clean all over the drum unit being careful not to directly touch the drum surfaces (they scratch very easily causing permanent marks to print) also vacuum out the inside of the printer. It is likely that dust is preventing correct charge build on the drum. Also make sure the green slide tabs are placed back at the home position at the side of the drum unit. Re-assemble and test.
Oct 13, 2016 | Brother HL4040CN Laser Printer
Brother HL 4050 CDN suddenly got DRUM ERROR, and there're message slide green tab on the drum unit in
The green tab slides from left to right.
This cleans the croner wire. These wire also have a tedancy to break every often.
The drum unit will need to be replaced
Feb 15, 2011 | Brother HL-4050CDN Printer
Brother printer 4070CDW drum error slide green tabs on each color
Open up the printer and slide the green tabs to clean the drum chargers
Jun 17, 2010 | Brother HL-4070CDW Printer
My brother MFC9840cdw has an error message that says, "drum error, slide the green tab on each of the colored drum units. Refer to the users guide". I have tried sliding the green sliders several times. I...
The guy that replied solved the problem. He rocks and I can't believe that brother does have a large posting on this issue. Sham on them:
ben2913 did the job "This is NOT the solution to this error code. The code is telling you that the Corona wire must be cleaned. Remove all 4 color drums. Look down into the tray that you removed them from and you will see 4 green tabs. Open the plastic cover that protects the corona wire and move the green tab back and forth several times. After you have done this with all 4, reinstall the drums, close the machine front and everything will work fine again."
Feb 25, 2010 | Brother MFC-9840CDW Laser Printer
Drum Error: It says to Slide the Green tab on each color drum to correct problem. I do it on all and nothing happens error continues.
this printer has 6 Drum, check all, and look internal counters is available on the menu they are down counters. If Continues go the Brother Repair Center, for repair.
Nov 01, 2009 | Brother HL-4040CN Laser Printer
Newly set-up Brother color laser printer displays drum error.
The slides you are moving are for the drum units, you could try using canned air to blow in the same area that the sliders slide across, if that doesn't help you may need a new drum unit..
Aug 21, 2009 | Brother DCP-9040CN Laser Printer
Brother 4070 CDW Drum Unit Error
The green tabs that you have to slide are under the color cartridges, so remove the three color cartridges and you will see three green tabs, to slide the tab across the wire you have to first open the translucent plastic wire cover, then slide the green tab across the wires and return it to it's original position, close the wire covers, replace the color cartridges, and reassemble the printer. All the Best
Jun 11, 2009 | Brother HL-4070CDW Printer
Drum error : slide the green tab on drum unit in each colour?
you forgot to slide the tab, unless you do this you cannot use your printer im afraid, drum unit is a cylindrical part unit, unless otherewise you correct this instlltion procedure there is no othere way around it
cheers
Nov 25, 2008 | Brother HL-4050CDN Printer
Brother HL4040CN Laser Printer Logo
1,146 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
