Question about Ricoh Office Equipment & Supplies
Savin 3515 MF - when printing - Intermittently but often it prints where you can see shadow print from some other item that has printed before it. I keep going in and cleaning the roller (just wiping it off) and that seems to keep it ok for a while. We just had all the rollers replaced and the photoelectric unit replaced about 3 months ago.
  • 1,110 Answers
There are only 2 possibilities with this problem. 1 is the PCU or Photoconductor Unit. I am guessing that this is what you had replaced 3 months ago? If so you may have to have the dealer replace it under warranty. The other possibility is the fuser unit and fuser rollers. I would not suspect these as much because if the fuser rollers get bad enough to start double imaging then they will usually do it every copy, not occaisionally.
The hardest part of your issue is in the fact that it is intermittently happening. If it were every copy/print then I would suggest shutting the machine off while in the middle of the copying process so you counld see if the double imaging was there before the page went thru the fuser. If it were then that would prove the PCU was at fault. Since this does not happen all the time, that troubleshooting technique is of little to no use.
When you say cleaning the roller are you taking about the drum? The Greenish/Blue colored "cylinder" that you see after opening the right side door? That cylinder or drum should always be clean as it is cleaned by the drum cleaning blade after each copy is produced. If you are having to clean it manually then I would suspect even more that the PCU is bad. If this is the case then I would really complain to the dealer that installed it. Also if you have the service order when it was replaced that should give you the page count when it was installed. Check that against the current count. The PCU is suppose to last at least 45,000 pages.
Good Luck and Thank You for using Fixya.
Posted on Sep 03, 2010
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
Savin c2824 wont print pdf files
If its showing drivers for a different machine then the first step should always be to completely remove and reinstall the drivers for the correct unit.
Mar 02, 2012 | Savin Office Equipment & Supplies
Printer error 3515
Kodak ESP-5 error message 3515....tried Kodak way but didn't work....could hear the print head attempt to move but couldn't...unplugged unit from power....opened to expose the print cartridges...removed small screws on sides and back of printer...gently pry open top....turn gears on right side with finger toward front several turns.....check and see if print head will now move to center....(I removed cartridges and print head so I could see the blotter under print head move to back position. Re-installed print head and cartridges.) plugged power cord back in and turned on...unit cycled and then screen showed normal....replaced screws in top panel.....printed test page...back in operation......Don't be heavy handed....plastic will break very easy I think when opening panel if not careful...
Dec 28, 2010 | Kodak ESP 5 Printer
Can not connect my SAVIN 9925dp copier to a computer.
depends. these machines did not come standard with print option. do you have that option? if so does it have a parrell or nic? the nic is the new stanard connection, ethernet j45 connector. are you printing mac? if so you have to have the post script ooption in addtion to the nic and print card.
Sep 25, 2009 | Savin Office Equipment & Supplies
I have a Savin 9400 copy machine. It will not print 2 sided copies. Everytime I try to print a 2 sided copy, it jams after it prints the first side and before it prints the second side.
Hello sir; You need to clean the reverse roller with alcohal, if you don't know which one is reverse roller then you can clean up all the roller in duplex unit.
Aug 28, 2009 | Savin Office Equipment & Supplies
Savin 2513F, prints PDF files intermittently
I'd try a different driver, if your using RPCS, change to PCL5. You may have to upgrade the firmware in the copier too.
Aug 26, 2009 | Office Equipment & Supplies
Savin 3515
What you have to do is go to file| print| then click pages _ to_ and type pages 1 to 1 then print, then place the printed pice of paper back in the printer tray. then type print pages 2 to 2
if this is not what you mean then File| print| click properties next to your printer name. Then click advanced and enable 2 sided printing
Sep 03, 2008 | Microsoft Office 2003 Basic Edition...
Savin 8045e copier
That depends on what you are printing.
Any time you read stats about page count, it is usually based on 30% coverage of the page.
Depending on what you are printing, it can be more or less.
Estimated yield is 30,000 pages for a standard cartridge.
Using an aftermarket (refill) cartridge can vary greatly.
And as mentioned, it really depends on what you are printing.
Aug 05, 2008 | Office Equipment & Supplies
501 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
