Question about Hitachi P50S602 50 in. Plasma TV
Tengo tv hitachi p50s6001con fuente mpf 7726L que no prende solo parpadea led azul.porfavor que hago l
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: fuente conmutada no funciona tv ilo model lct32ha36
AKAI makes iLO TV, here is the service manual, diagrams:
http://elektrotanya.com/?q=showresult&megnev=&megnev2=LCT32HA36&kategoria=tv&kat2=all
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 17, 2010
  • 10865 Answers
SOURCE: tv philips 42pf7320. prende ,peroluego
Hola! El calentamiento podr?a valer la pena el electrolytics ups con un secador de pelo antes de encenderlo. Tenido un problema similar en un plasma Philips causada por una duff condensador.
Jose'
Posted on Oct 14, 2010
bbl242003
  • 1637 Answers
SOURCE: Buenas noches, tengo una hitachi
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
Tv samsung no enciende solo se escuche una oscilacion, chasis cl17k10mjzxxax
porfavor pregunta in el clasification para TV ,esta es los coches e segura niguno de nos altras mechanics sabe esta
Mar 20, 2012 | Cars & Trucks
Mi televisor no enciende solo se prende el foco rojo y parpadea en donde dice timer
bueno tengo una television pt4298hd akai el problema no enciende parpadea el foco de timer 10 o 9 veces y no enciende destape la tapa de atras y desconecte un cable rojo que tiene el nombre de screm y la television enciende pero no se mira como debiera porque se mira el color verde y el rojo pero como si le faltara el color azul mi televisor es una dlp akai de tres lentes y quisiera saber cual es el problema
May 02, 2011 | Akai PT4298HD Rear Projection Television
Mi televisor se prende y se apaga tiene tres focos en la parte delantera uno dice lam temp power el de powewr parpadea y no se queda fijo que puede ser
mi tv ultravision hitachi prende y se apaga lo desconecto y lo conecto y prende y hace lo mismo y m parpadea la luz roja d temp q sera ?
Dec 09, 2010 | Hitachi UltraVision 55HDS52 Television
Bunas dias , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes...
Que tal yo tambien tengo el mismo problema con mi tv insignia de 32¨ , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes estan presentes a la salida de la fuente, cambie todos los filtros de la fuente pero nada, gracias por su ayuda.
mi corre es carlitoswwway@hotmail.com
Nov 30, 2010 | Insignia IS-LCDTV32 32 in. Television
Tengo una olevia de 42 pulgadas y de rrepente dejo de encender y la luz azul se queda parpadeando. que hago?
hola, me parece qe tu fuente de poder se daño, si es posible destapa la television, antes desconectala de la corriente electrica. en la fuente, observa los capacitadores talves alguno se exploto o se rego el liquido qe llevan adentro. Esto es muy comun qe falle en las televisiones.
Dejame saber si necesitas mas informacion
saludos
Aug 25, 2010 | Televison & Video
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
No prende ya mi monitor
Hola, Su monitor tine un problema de unidad de fuent la luz O la connector de VGA tiene unas pins dentro la connector danados.
1. puede chkar los pins
2. comprar una unidad fuente da luz
Si su monitor tiene una garentia por fabrica yo recomendar usted llamar esta fabrica para un reperacion.
Disculpe yo no puede escribe moy buen in espano espero que usted si entiendan.
Por favor vota moy bien para esta solucion si usted encauntra the solucion si ayunden.
Gracis
Atte Rulds2008 - GURU
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 24, 2009 | Princeton Digital VL2018W Monitor
Hitachi P50S602 50 in. Plasma TV Logo
227 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
