Question about Cycling
Inside cartridge system and height adjuster spare parts
4 Suggested Answers
alicantecoli
  • 22246 Answers
SOURCE: 2004 VW Golf Rear Brake Caliper Adjustment
put a g clamp on it with slight pressure ,then turn it in a bit G clamo goes loose tighten it again and screw it in a bit more and so on--- or have a helper keep pressure on clamp whilst you turn the piston with a pàir of water pump pliers
Posted on Apr 04, 2009
  • 363 Answers
SOURCE: best height of inside unit of a split AC
which type of mounting is suggested wall or ceiling, if it is suggested that wall mount is nominal then the height is optional, mount it as high as possible. If ceiling mount is suggested then closet to outside wall as possible
Posted on Jul 26, 2009
c1apton15
  • 3400 Answers
SOURCE: Hello, I have been triyng to find a spare motor
Have you tried these guys?
http://www.vwpartscenter.net/partlocator/index.cfm?action=getJointLocator&siteid=215911&chapter=§ionids=0,51873&groupid=51876&subgroupid=11071&make=35&model=Touareg&year=2004&catalogid=2&displayCatalogid=0
Posted on Mar 07, 2011
Testimonial: "yes, thank you VERY much. have a good day sir"
Hot and cold
If this is a thermostatic shower then it sounds like the cartridge inside is failing, it a fairly common problem, but easily replaced, they will look something like this 4_5_2014_7_51_26_am.jpgand are housed in behind the knob/dial, these can be purchased here Steam Shower Parts Spares Cabins Enclosures Parts or from here http://www.thermostaticcartrdges.co.uk/
Jan 09, 2014 | Home
Water on right side of trunk and spare tire well in my 2006 honda civic
It is most likely the boot rubber seal there is commonly two rubbers that adjusts the boot close height see if you can turn the right hand adjuster in to make a firmer seal. Also check that the seal is not pinched and is located properly. After market rubber is not expensive if you want to try to replace the whole seal.
Jan 31, 2013 | 2006 Honda Civic
How to lift the body of the car?
you can fit coilspring boosters. it is rubber spacers that fit inside the spiral of the coil spring. you get different sizes for height adjustment from your local spares shop.
Nov 27, 2012 | 1990 Oldsmobile Toronado
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
I need the handlebar wires that make the height adjustable handle work on the quinny buzz 3 any ideas?
Hi - The wire from inside the Quinny Buzz handlebar isn't available as a seperate spare part item. To replace it, the entire handlebar is required, which comes complete with the inner workings. How old is your Buzz? If it is under 2 years old, please contact your retailer with your proof of purchase to make a claim under the terms and conditions of the warranty. If it is over 2 years old or you do not have proof of purchase please contact the customer service department for your country - for the UK this is 01284 413 141 Mon-Fri 8.30-4.30
Nov 28, 2011 | Quinny Buzz 3 Stroller
I am looking for a Fisher & Paykel Smart Drive 601 washing machine "corner cabinet foot assembly". Just the large corner plastic foot. The height adjuster is in tact. The corner piece is...
As you no doubt know already FixYa doesn't supply parts direct- not unless you're very lucky and someone from anywhere in the world just happens to have what you want at the bottom of a pile of bits in the garage!
You could try looking on line for more spares suppliers. You will need to type into your search engine/web browser '(make) washer spares' and you may be presented with a number of sources from which you may be able to order. During the process you will be asked for the actual model number.
Good luck- 'cos it's frustrating, isn't it!
John C
Mar 29, 2011 | Fisher and Paykel GWL11 Top Load Washer
The handle bar on my silvercross linear sleepover pram system has snapped, where at the height adjustment buttons, can i get a new handle for my pram?
hi bex_901. you can contact the retailer where you bought thestroller. you can also email silver cross about the new handle for your pram.surely, they have an available replacement for the handle. please check the link iprovided below. thanks for using fixya. good luck.
https://www.silvercross.co.uk/contact/spare-parts/
Jun 28, 2009 | Silver Cross Baby Gear
Apr 04, 2009 | 2004 Volkswagen Golf
Rear air ride suspension is not maintaining height
The are ride height adjusters the look like arms. they are mounted on the bottom of the struts and lower control arms that control the height The can be adjust but for the most part if the were working fine before then they need to be replaced. Make sure that there are no leaks in the system.
Dec 29, 2008 | 1997 Lincoln Continental
Cycling Logo
596 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
