Question about Samsung Heating & Cooling
I have a model AW189CB samsung widow air conditioner. Its 4 yrs old. I keep the filter clean but for some reason but for some reason water is now dripping out the front of it. It has the slope needed to drain outside. I have never had a problem with it untill recently. I took the front cover off and there was lots of condesation on the front copper piping and the plastic tray below it was full and dripping out the front. Any ideas? Thank you David Lewey
  • 24 Answers
The front copper coils need to be cleaned
Posted on Sep 03, 2010
My AC unit leaks water inside
Isidro, If it's a window unit you will need to tilt it up from the inside. Thank you and please leave me feedback. Clean around the bottom of any debris so it can drain on the outside.
Jul 12, 2016 | Panasonic Heating & Cooling
The Model Number is BRCQ0361BD AND IT IS 12YRS. OLD. WHAT CAN I REPLACE IT WITH AND WHERE CAN I FIND IT?
unless its been abused ie coils not cleaned, coil damage, or compressor bad its worth repairing. should get another 5 to 8 years out of it.
Aug 18, 2015 | Coleman Outdoor Split System Air...
Ductless split LG LS240CP keeps cycling on and off every 3 minutes without reaching room temperature
Any number of reasons. Low freon pressure is one. Dirty filter (wash with plain water) obstructions causing airflow problems. Don't confuse temp on remote with temp on face of unit. LG in the Philippines means "el gigawa" translation: fixalot! I owned 5 LG products all repaired multiple times. Now replaced with Samsung. If the unit is old, replace with Samsung $3000 or less but worth it.
Sep 25, 2013 | LG LA185HV Split System Air Conditioner
Have at home a Samsung Split system AQ24B1QE approx 11 yrs old, leakes water from top, tried cleanig coil and filter still doing the same thing.
Water leak: It's because of non-maintained air conditioner. Clean airfilter, indoor coil, blower wheel and also drain pan. Insulate freon pipelinesproperly and tightly. After that run the a/c. If still water dripping. Checkindoor f.motor speed. If less replace capacitor. If f.m. is o.k, check gaspressure. If less, there will be ice formation over the coil and water drippingwill be there when it melting. If short of gas, check for leak andrectify. Thanks. Helpful?
Jan 24, 2011 | Samsung Heating & Cooling
Air con is working, but not cooling the air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 05, 2011 | Samsung AS18A6RB Air Conditioner
I need a manual for a AW189CB Samsung air
You can get the manual on the link below.
http://downloadcenter.samsung.com/content/UM/200604/20060421130459515_DB81-00656A-E-1.pdf
Good Luck and please rate 4 thumbs for the free answer
Jun 06, 2010 | Samsung Heating & Cooling
Air conditioner is tripping after one hour
clean filter and Evap coil and condensing coil. also some units have a gfi breaker at the plug witch some times go bad
Apr 08, 2010 | Samsung AW1203B Air Conditioner
IT IS ABOUT 4 YRS OLD AND THE WATER STARTED TO
I would not advise using bleach. I would disconnect the pipe from both ends and blow down it, either by mouth or air gun to ensure of no blockages. You should poor away at least 10 cups of water after changing filter to ensure clean fresh water.
Dec 15, 2009 | KitchenAid Superba KSRG25FK Side by Side...
When I keep my air condition on auto and it has ran then turns off when the temp. is reached it has began leaking
your unit needs cleaning.
when fan is running, it creates a vacuum that hold the water from spilling from your unit, then at auto, as the temperature is reached, the fan would stop and the vacuum that keeps the water from spilling would disappear and starts to leak water.
have ti clean....
that would eliminate your problem..
tnx 4 using fixya,
drcool
Aug 27, 2008 | Heating & Cooling
Heating & Cooling Logo
140 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
