Question about Goodman Heating & Cooling
We just installed a new Goodman HVAC and the compressor lines freeze up. The technician that installed the unit cannot find the problem
  • 24 Answers
Not to be critical, but not much of a technician if he cannot properly troubleshoot the issue.
Several issues can cause the freezing problems:
1. Refrigerant charge issue.
2. Improper equipment sizing.
3. Air flow issues.
4. Metering device issue.
First is under charge. But before making this determination several other things must be diagnosed and resolved.
Was the unit sized properly using a heat load calculation? You may not know what this means but a reputable, knowledgable contractor does. If the unit was oversized, it can cause the unit to freeze. If the indoor fan & motor were undersized. it may not be moving enough air across the coil and this will cause the coil & suction line to freeze.
Air flow issues, such as obstructions in your ducting or across your evaporator coil will cause the coil to freeze, thusly your suction line will freeze as well. Is the filter and evaporator coil clean? Are there any obstructions in the air passages (duct)? Is the duct work sized properly. Improper sizing of the duct work may choke down the required return air flow, and cause the coil to freeze.
The last issue could be a problem with the metering device. If it is an adjustable thermostatic metering device, was it setup to maintain a 12 degree suction superheat? If it is a fixed metering device, such as a cap tube device or bullet (orifice) device, it mat have a restriction (ususally a piece of solder or flakes from the soldering process clogging up the inlet screen). To easily check this, thaw the system out, start it back up when thawed and look for frosting or ice accumulation at the metering device outlet side. I fit does this rather quickly, then the system must have the refrigerant recovered (or pumped down into the condenser) and the blockage removed.
If it is air related, this must be fixed prior to properly trying to charge a system. Unless the proper airflow has been established, charging the system, or checking charge cannot be properly performed.
Posted on Sep 04, 2010
Bad condenser unit GOODMAN
it is a 3 ton condensor you still can buy r22 freon condensors new but they have nitrogen charge and its expensive to charge I recommend to go with 3 ton goodman condensor which is new 410a puron and also change indoor coil and flush the line set so you dont endure the high cost of new copper lines these new systems come with 10 years warranty and the r22 systems come with only five years
Feb 26, 2013 | Heating & Cooling
All the coils on the unit outside froze up
Hello, if the inside fan was not running then the evaporator coil cannot absorb enough heat to vaporize the refrigerant, and the suction line will freeze including the compressor. Liquid refrigerat instead of vapor passes thru the suction line into the compressor. Lack of airflow or a low refrigerant charge is what will cause the line to freeze. In your case it was no airflow
Jun 14, 2012 | Goodman Heating & Cooling
Have a Goodman AC unit (model: GSH130421AA) in my two story town home. The upstaris does not cool, however, downstairs does. The outside pipe(?) that leads into the AC unit was frozen; looked like a snow...
Hello, when the pipe freezes up it usually indicates a airflow problem or low refrigerant charge. Check the air filter, blower wheel for any dirt. Also, make sure the blower motor is running. If the airflow checks out good then the unit is low on refrigerant and must be recharged by a hvac technician.
Jun 04, 2011 | Heating & Cooling
Unit not cooling
Low on refrigerant charge! Low side line should be cold like a beer can at the inlet of the compressor with some sweat beads around it. 55deg. The discharge should be around 125deg just hot enough you cant hold it long!
Jul 26, 2010 | Goodman CKL60AR60 Air Conditioner
3 year-old Goodman compressor/heat pump terribly loud @ start
I don't think this problem (btw I agree 'from a far distance' with the Hvac guy) is inherant to Goodman, after all the compressor (that is in the unit) is one that if found in other brands too.
Of course the compressor is under warranty so there's no charge for it - but - $800 to change out the compressor (and that's the proper fix) is a 'bit' high - you possibly could save a few bucks by getting some other estimates.
good luck!
May 09, 2010 | Goodman CKL60AR60 Air Conditioner
Air compressor keeps freezing up...copper line had been without insulation until yesterday, but this didnt fix the problem. Unit is a 2 year old Goodman
The thermostate is not working properly, thermostat sense the temperature of the sitting and it work like a switch cutting compressor on and off. When the thermostate sense the correct sitting of the temperature and it suppose to cut off compressor to allow the evaporator to warm up a little if the thermostat switch is faulty and it does not recognize the temperature although it will keep the compressor running until it freezes up just like froze water stuck in the line.
Aug 13, 2009 | Goodman Heating & Cooling
Goodman furnace was installed on its back- Problem?
The furnace can not be installed with the doors facing up. It will not work properly and yes it is dangerous. The unit needs to be flipped to its side, and the plenums and the ducts need to be changed around along with your Flue (vent) pipe, and gas line. HVAC-R Tech
Feb 04, 2009 | Goodman GMS90703BXA Heater
Goodman unit freezing outside the unit
Its not the thermostat.
The things that can cause this problem are lack of or poor airflow over the Evaporator coil. Or a low system charge. Or quite possibly a restriction in the line on the low side. When they replaced the compressor did they purge the line set with nitrogen and pull a deep vaccum? This is imperative when replacing a condensing unit to ensure that no residual particles are left in the line set to create a restriction.
Hope this helps You
please rate me
Jul 24, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
200 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
