Question about Xerox Phaser 6180N Laser Printer
I have a Xerox 6180 MFP I keep getting an error message when I am trying to print on 8.5X14 paper out of what I think is the paper tray 1. What am I doing wrong
  • 398 Answers
SOURCE: printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
Posted on Jun 26, 2009
don_farr
  • 1018 Answers
SOURCE: wrong size paper jams
Take a trip into the Printer Driver for this printer and then select "Printer Properties"
Review the settings for the paper setup. Also, from your application, make sure you have "Letter" set as the desired page size.
Finally, if your printer has a "Paper Menu" go into that and set tray size to Letter.
Don
Posted on Oct 21, 2009
SOURCE: Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Posted on Feb 28, 2010
  • 4 Answers
SOURCE: FUJI XEROX DOCUPRINT C1110 WRONG PAPER SIZE MESSAGE
This printer have a sensor to remind the user when using a wrong paper size.
If you still using a paper that not the same with your software settings, it's still reminds you.
I solve this promblem by after print my works I just press "Cancel Jobs" button to clear a data.
Good luck.
Posted on Mar 23, 2010
wrinaldo
  • 185 Answers
SOURCE: Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Posted on Aug 10, 2010
How do I fix a printing problem where the error message load tray 1 keeps appearing?
You Really need to have this Machine Cleaned. there is too Much Paper dust On the sensor
Jun 06, 2015 | Xerox 6505/dn Workcenter 6505dn Color...
Connect 6180 MFP scanner to Toshiba laptop
Press the document to be scanned on the Platen glass. Press the Scan button, an Utility will appear. Select required size and resolution. Upon scanning document, save it in compatible format and attach it to email.
Jan 08, 2014 | Xerox Phaser 6180 MFP/N Letter-Size Color...
Xerox 6180 James at Tray 1 mpt every time!
Your lower trays are programmed incorrectly. Change the size and or the paper type back to letter and plain paper
Aug 23, 2012 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 6180 keeps saying load papertray with
Remove the paper tray and check the guides. Make sure they are lined up on the 8.5 X 11 marks. If it is lined up, try going into the menu of the printer and reset back to defaults.
Jul 21, 2011 | Xerox Phaser 6180N Laser Printer
When we print to Xerox Phaser 6180 the print job prints the first page from tray 2 and then wants tray 1 loaded with paper to finish the print job. The paper in tray 2 is 8.5 x 11 the same that is...
I suspect the machine is on a network and the driver is installed on the server. Your workstations driver properties are probably not the same. i have seen this problem quite a few times and its always been down to configuration and not a fault of the printer. Basically a printer prints what it is sent and to where it is sent.
Good luck
Jun 01, 2011 | Office Equipment & Supplies
HP 9050 MFP keeps asking for tray 1. Configuration is set to use tray 4 first, but everytime a print job is sent to the printer, it requests load paper in tray 1. How do I get this problem fixed?
You need to check the paper types you have assigned and the paper types that users are requesting. Print out a configuration page and make sure that Tray 4 shows as plain paper. If it does not then check all the stops. The 2000 sheet tray 4 units are noted for having the stops not engage and this causes the printer to think that tray 4 is custom media. You can also go into diagnostics and print a paper path test for each tray to ensure that all the trays are working.
Apr 21, 2011 | HP LaserJet M9050 MFP Printer
Xerox phaser 6180 MFP displays errorr message and code BLK CRUM ERROR 093 925 restart printer problem occurred when a fax was being received
This error message points to either
1 A corrupted chip on the toner cartridge.
2 The wrong chip on the toner cartridge. There are several printers that take the same basic cartridge, the difference being the chip.
If you have just bought the cartridge, return it for replacement.
Oct 06, 2010 | Office Equipment & Supplies
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Sep 03, 2010 | Xerox Phaser 6110 Laser Printer
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 6180N Laser Printer Logo
63 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
