VIZIO VS42LFHDTV10A There is a wide red, sometimes yellow band on left side of screen when the TV is first turned on. After the set is on for a while it goes away. Before we call for Costco service, is there anything I can do to correct this problem. Thank you. LA-CT
SOURCE: Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
Posted on Feb 18, 2009
  • 1779 Answers
SOURCE: red line down right side of screen
I would have a tech come out and look at it. Sometimes the ribbon connectors from the upper or lower buffer boards have poor or corroded contacts. Should'nt be a major deal since it comes and goes.
Posted on Apr 21, 2009
  • 187 Answers
SOURCE: Vizio P42hd approx. 1" red line on screen, picture shifted
You will need to replace the control board and your TV will be better that a new one.
Posted on May 27, 2009
  • 187 Answers
SOURCE: VIZIO VS42LFHDTV10A Freeze Up
Just unplug the comcast and see how the tv works, if the TV works fine, then you will now the trouble is not your TV.
It is not likely to have the same issue in the new TV, just unplug everything and use a dvd to see how it handle it.
Posted on Jun 19, 2009
  • 586 Answers
SOURCE: two inch wide vertical band spreads across half of screen
The problem is in vertical section and the faulty components are :
1- Capacitor
2- Transistor
most probably the poped capacitor must be the reason, check and replace the faulty components.
Thanks for using fixya.
Posted on Jul 01, 2009
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Light vertical band about 3.5" on left side of screen
The cost to repair this "convergence" issue is about the same as a new TV. Stay away from Toshiba TV's they have allot of problems. I have found for the cost that Vizio (sold at Wally Mart, Costco, Sam's club and others) has excellent prices and few problems.
Jan 19, 2012 | Toshiba REGZA Televison & Video
Change screen from wide to regular our cable guy put it on wide my control will no longer change it
Vizio has a set of buttons on the left side where you can access your settings and change the aspect ratio of your TV. Though why you want it changed is beyond me. Wide screen is for 16:9 aspect ratios. At 4:3 (Standard) you won't be using your full TV picture.
May 19, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
May i know, where i can get a spare parts of this screen LCD Vizio Model: VS42LFHDTV10A ?
visio.com have links to local authorised parts sellers
please let me know if you require firther help
Jan 18, 2011 | Vizio 42 in. LCD TV
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Red in left sie of screen show up sometimes on 42 samsung SP P4251
What component(s) are you connected to this TV?And what type of A/V cables are you using?
Does it only happen when you watch cable or directv or dishnetwork?
solutiondoct
Nov 06, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Blue color spread over the pictures
This sounds classic to a thermo problem where a part(s) are becoming thermo sensitive with aga and use. When the set is cold and then warmed up, the defective part(s) is changing characteristics.
Some components became thermo sensitive that are driving the display. Or an embeded component in the display itself became thermo sensitive. It is very possible that the fault is on the board that does the X - Y addressing or on the backplane electronics of the display screen itself.
Using the set with defective components is a bad idea. If the part(s) fail completely and go shorted or opened, other more costly damage can be done.
The service rep for the manufacture of your set is equiped and trained to be able to troubleshoot and service your set.
You will have to take the set in to have it serviced.
Jerry G.
Apr 17, 2008 | Vizio GV46L 46 in. LCD Television
Vertical Red Line
Oct 23, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
