Question about Taylor 632-27 Ice Cream Maker
I have a 754 Taylor with 404a refrigerant The side I am having the trouble with will not stay running long and stops. The product is to soft to use. I have tested the prob that tells the unit it is cold enough. The freon is full on that side and I exchanged the board with one that worked and still no luck. Is their anything else I can try
    Scholar:
  • 81 Answers
The probe is not used to determine viscosity. This model determines viscosity by reading the amp draw of the beater motor. The viscosity setting on the upper control board is for fine tuning. You need to check the lower board. There are jumpers on that board that determine the amp range of the upper board adjustment. Most machines running soft serve are on the five range. Your machine may be on a lower range setting. All you have to do is remove the jumper and place it on the desired setting. Of course, there could be other problems that cause this issue such as a bad beater motor etc. Hope this helps.
Posted on Jun 18, 2011
  • 101 Answers
OVERRUN AFFECTS THE TEMPERATURE AND CONSISTENCY AS WELL. MOST MACHINES RUN WITH A 60/40 RATIO OF MIX AND AIR.
Posted on Jan 15, 2015
Does the taylor model 8756 put out a substantial amount more product than the 754?
Absolutely! The Taylor 754 and Taylor 794's are capable of 284 3 1/2oz. servings per side / per hour. The 8756 is capable of 426 of the same 3.5oz. servings. The 8756 packs more air into the product making it easier to freeze and reducing recovery time.
Soft Serve Parts Taylor Machines
May 07, 2017 | Taylor Ice Cream Makers
Standby keeps turning on when in standby but auto works turns itself on and off fine. Both sides of unit
I don't think you have a problem... I have a Taylor 8756p-27. In standby mode with my unit the beater motor turns on for about 15 seconds every 15 minutes and the compressor turns on as needed to keep the mix at a safe temperature. This is what standby mode is supposed to do. If you don't want it to turn on and off so much in standby mode, perhaps leave it in AUTO mode and it will turn off and on as it needs to to keep your product at the proper temperature.
May 06, 2015 | Taylor 754-33 Ice Cream Machine Soft Serve...
Hello I have a 8754 Taylor and having trouble with the (chocolate)left side of the machine.The product goes soft after I've served about fifty cones. this is what I've tried *installed all new o rings...
sounds like a freon like to me if the compressor is running for long periods and not freezing properly or you have a water pressure issue. if it is water cooled which alot are it is hard to realize you have a freon leak.
Dec 12, 2014 | Taylor Ice Cream Makers
How to recognize why 339 raylor is not giving good product viscosity
If the machine runs and runs and can't satisfy your viscosity setting there is a refrigeration problem. The longer the machine runs the more the product breaks down, so you're problems get worse as the day goes on. It's not uncommon for these machines to lose refrigerant. I would guess that is the issue here.
You will need a refrigeration repair person to put gauges on the machine.
Here is some information I put together about the logic board adjustments on your machine. I think you might find this helpful.
Taylor Softech Control Boards
May 28, 2017 | Taylor Ice Cream Makers
Why is my taylor 8756 - 27 freezing the chocolate side and will not dspense?
This seems like it could be many things. Is the pump coming on when you try to dispense? Can you stick a thin wire up through the feed holes in the chocolate side when you try to dispense to help free the product?
May 04, 2014 | Taylor 754-33 Ice Cream Machine Soft Serve...
Product comes out frozen after all night on standby in a 754 taylor
The same thing happened to my Taylor 8756 and it was the thermistor probe. The probe is a thin copper tube that is near the freeze cylinder. It cost me about $20 for the part and $200 for the labor to have a technician put it in. Hope this helps and good luck.
Apr 18, 2014 | Taylor 2001 754 Air Cooled Soft Serve...
I have a Taylor C713 Ice Cream Machine. IT has been working great until a few days ago. We had it in standby overnight and when we came back the next morning, the ice cream in one side was rotten from...
Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
Soft Serve Parts C713
Nov 11, 2013 | Taylor Frozen Yogurt C713 Soft Serve Ice...
My Taylor 754-27 on the right side will stop workng just as the porduct gets up to consistancy. Do you think it is a weak or bad motor. The motor just stops and then when the product starts to warm up I...
Hi Lori and welcome to FixYa. I am Kelly,
If you have someone capable of swapping controllers between units move the controllers side to side by exchanging positions. I think you have a controller problem. Via the viscosity control (soft / hard) it senses amperage of the motor while in use. You either have a bad controller or a bad temp control. If you swap controllers and the problem persists then the temp control is bad. If the symptom changes to the other side then the controller is bad.
Thanks for choosing FixYa,
Kelly
Mar 26, 2011 | Taylor 632-27 Ice Cream Maker
Taylor 770 soft serve
754-27 Taylor soft serve machine Beater motor not running - compressor not engaging - Power to beater relay but not out of relay.
May 18, 2008 | Ice Cream Makers
Ice Cream Makers Logo
720 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
