Question about Baby Gear
Trying to setup my Combi pack n play -- the sides won't lock and it's getting very frustrating. Ho do I get it to work? Thanks.
Lock the sides up before you push the center down - I had the same trouble!
Posted on Nov 23, 2010
Graco posey pack n play side won't lock in
I've had this problem b4 and all I had to do was to **** it up really hard and fast, then it would catch and lock. Hopefully it will work for you too. Good luck! :)
Jul 11, 2012 | Graco - Pack N Play with Newborn Napper -...
Lost one of two bolts on Combi USA pack n play model 9400 -- the corner with the light and music -- and it won't stay together. Can't find replacement at any hardware store. Help!
Call Combi and explain that the bolt has fallen out and is missing. I am sure they will send you one. Customer service will work for you if you are nice and if all else fails maybe they will sell it to you. Couldn't cost much.
Toll Free: (800) 992-6624
Feb 11, 2012 | Graco 9445DOH Crib
My Technika TV/DVD Combi was playing a DVD but then made a noise like it was trying to skip tracks before going off. When I try to go back on to the DVD it says "no signal" and won't...
Hi.We can't help you here. Take it to a repairman. Inside you maybe able to check for a fuse but nothing else. If the cost is more than a new TV than you can decide for yourself. Good luck
Jun 28, 2011 | Televison & Video
I cannnot get the gRECO PACK N play sides to stay up
I have the same one, its quite difficult.
It needs to click & lock in on both sides of the release buttons. Sometimes having somebody put their foot in the bottom of the play yard while you pull up on the release button will help lock it in.
You also need to have the shorter sides lock in first before trying to lock the longer sides in.
Oct 18, 2010 | Graco Pack 'N Play® Playard 9447mch
Problems re opening the Graco Pack N Play - one side won't lock
if so try always from turnig and pulling up the center and then with some help squeeze pulling up the side of each pack. then try to push everything down.
it's treaky and coming back blocked very fast. you have to manage all of them at the same time
Good luck
Pls let me know if I helped
May 26, 2009 | Graco Pack 'n Play
Trying to open my combi playpen
lock the side rails up first thing before you do anything else. make sure the bottom is all the way up, then lock sides spread feet apart and push down in center
Apr 10, 2009 | Baby Gear
Folding up Cosco play yard
My wife and I have the same model for visits by our granddaughter. She was having the same trouble as were you and, like you, we did not have instructions.
I'm happy to share with you what I found to close the model up for storage. It may not be the same as what the manufacturer envisioned but it worked for us.
-- With the pad removed from the inside of the Pack n Play, pull up on the red handle so as to loosen the legs;
-- Next, you will find there is a big button in the middle of each of the long sides of the Pack n Play. Start with either long side. You will have to press very hard on either side of that button; I found it helpful to use both hands, one pressing on the outside of the playpen, the other hand pressing on the inside of the playpen. Pressing these together will loosen the long support arm at the open top of the Pack n Play.
-- Do the same for the opposite long side.
-- You will also do the same, one button, one side at a time, for each of the two short sides of the Pack n Play.
-- Now pull up on the red handle in the middle, and guide the four corners so they meet and close.
-- Cover.
I found the buttons may not have fully allowed the support arms to collapse, thus blocking the Pack n Play from folding down completely. If so, try pressing the button again (both the outside and the inside at the same time).
Hope this helps!
Jan 06, 2009 | Cosco Beatrix Potter Playard Crib
Cosco Playpen
-- Cover.
By the way, I've found it to be an exercise in frustration in trying to obtain an instruction manual from the manufacturer. I'm very disapopinted with this purchase and in particular this company.
Hope this helps!
Jul 01, 2008 | Cosco Beatrix Potter Playard Crib
Pack n play
Pack and Plays are VERY hard to get together if you don't do the steps in order.
1) Ensure the base is not pushed all the way down or flat. If it is down/flat, the sides will not lock
2) Your sides should snap up with a moderate amount of force. Double check that both arms of the sides are all locked in the up position.
3) Now you can flatten the base, insert the mattress pad, and you are good to use the pack and play!
Enjoy and happy napping!
Jun 16, 2008 | Baby Gear
Pakc & play set up
I had the same problem with the pack & play that I used for my youngest. It turns out that the centerpiece (looks like an extra leg for support of the pad) needed to be pushed all way down, where the leg was resting firmly on the ground, before you lock the sides. When it was time to fold the pack & play back up, you have to pull the middle up first for it to unlock properly.
I hope this helped!
Jan 13, 2008 | Graco Quattro Tour Kentshire Stroller
Baby Gear Logo
1,454 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
